bearing clearance on D4 front idlers.
callan
Send a private message to callan
could someone please let me know the minimum and maximum bushing to shaft clearance allowed on the Front idlers of a d4 6u
they are the earlier spoked type idlers.
the one idler axle shaft I have pulled out was very slightly bent which was a bit of a concern.
i put it in the press and put it back into shape. took about 20t.
plan to either replace the bushes and weld up the shafts and turn them down to original in the lathe, or simply build up the shafts to a larger diameter
and turn out the bushings to new clean bronze. this seems the most cost effective to me, just need to know what clearance to give it.
thanks.
Thu, Jun 28, 2012 11:20 AM
Thank you received: 63
New: 0.003 to 0.005 clearance
Max allowable 0.040
End clearance 0.010 - 0.028
Thu, Jun 28, 2012 10:27 PM
callan
Max allowable 0.040
thanks OM once again for your Help.
i expected the clearance to be greater, but now I know the 3-5 thou is the play when new these puppies are definately due for a rebuild.
Much appreciated.
Fri, Jun 29, 2012 9:37 AM
Reply to callan:
Much appreciated.
Correction:
New clearance spec. is 0.005 to 0.009
Rest of the numbers are correct.
I read off the clearances for the carrier rollers.
Fri, Jun 29, 2012 10:08 AM
