Battery rejuvenation
Showing 1 to 10 of 10 results
gary ca
The new generation battery chargers and maintainers advertise that they can reverse the process of sulfacation. I took an 8 year old Optima Red Top that was starting to show signs of weakness. It originally came with advertised 800 CCA. Using a Clore Automotive BA7 Solar battery system tester, these batteries often show 850 CCA when new. This battery was down to 624 CCA and would drop to 12.2 volts in 24 hours after the equipment was run.
I hooked it up to the latest generation Clore Automotive charger for a two week time period. My charger looks just like the Clore unit so I think it was made by Clore but rebranded. After 2 weeks, I took it off the maintainer and let it sit a day. The BA7 tester, which checks the CCA by measuring the resistance, showed it now had 815 CCA and the voltage was 12.6. One week later it showed 790 CCA and 12.5 Volts. I have not put it back in service yet but it does look like it was improved. I am currently one week into another test on an identical Optima that was down to 470 CCA.
The link to Clore Automotive is:
http://www.cloreautomotive.com/pro-logix/
Sun, Jul 24, 2016 6:20 AM
I've read that too looking at the Advertisements for the newer generation maintainers. Some thing about "pulsing high frequency to reverse Sulfication".
I have a maintainer that I rotate across a bank of stored batteries for the winter. I'm guessing it does help as I seem to be getting a few more years out of my 6 volt car batteries.
Sun, Jul 24, 2016 7:01 PM
DPete
Reply to drujinin:
Let us know the results, not sure how many batteries I have between machines, motorcycles, trucks, trailers must be over 35. I use deltran battery tenders including a 24V but if there is something better I'm in
1962 D4C
Mon, Jul 25, 2016 6:20 AM
7upuller
Reply to DPete:
Hey Team,
"He who Dies with the most Good Batteries Wins"!!!!
Hahaha
Mon, Jul 25, 2016 6:25 AM
gary ca
Reply to 7upuller:
Hey Team,
Hahaha
I called the tech department at Clore Automotive and asked about the ability of their charger to renew old batteries. The tech guy said that they will improve "lightly sulfacated batteries." My very limited test seems to back this up. The original battery described in the first post is still showing around 800 CCA. The second battery which started with 470 CCA out of the original 800 was not improved with a 2 week run on the charger. It is still close to the original 470.
I currently have the charger on a Blue Top Optima with an original CCA of 750. It is eleven years old and it now has around 100 CCA. I do not have much hope here but it is worth a try.
You cannot buy these chargers directly from Clore. They are the manufacturer and sell to retail outlets. They make several models and I think this line is called Pro Logic. Mine shows no Clore model number but I think it is a 2320. There are other maintainers making similar claims so check the descriptions and give it a try. They could be very effective if you start early in a battery's life.
Mon, Aug 1, 2016 8:07 AM
old-iron-habit
Reply to gary ca:
My friend Larry has a Honda 4 wheeler that still starts in our winters on the original battery. It is 12 years old this summer. He takes the battery out once a year and shakes the begeesers out of it while holding it upside down. He then gives it a 30 amp quick charge for 15 minutes or so and puts it back in the machine. He claims it keeps the power robbing deposits from sticking on the cores. So far it working for him. Now how do I shake my 100+ pound Cat batteries?
Mon, Aug 1, 2016 8:20 PM
chriscokid
Reply to old-iron-habit:
Interesting Roger, never heard of that.
I guess i can use my industrial paint shaker for batteries now.
Mon, Aug 1, 2016 8:43 PM
biggastractor
Reply to chriscokid:
I was told one of the reasons that newer car batteries fail early is that the distance between the bottom of the plates and the bottom of the battery is much less than it was previously, ( a manufacturing cost savings?). Anyway, in this case a battery could fail when the sulfate falls off the plates and fills the bottom of the battery up to the plates and therefore it shorts out. Does shaking it upside sown remove any of the sulfate? If so, that might help longevity of the battery.
Good luck
biggastractor
Tue, Aug 2, 2016 8:53 PM
cojhl2
Reply to biggastractor:
Good luck
biggastractor
When I was in HS I had a 47Ford PU. I added at one time some magic powder that was supposed to keep the battery like new. Well during the winter when the PU was not driven (no $ for gas) the battery froze and cracked.
After that it would not hold water but I just kept pouring water in it and it ran the whole next Summer.
I never kept track but I think between battery water and engine oil it was a match as to which used the most.
I've never known what that stuff was but it came in three small tubes, one for each cell of the 6v batt.
Note: drove that PU most of the way thru college before upgrading to a 48Buick. Wish I had them both now.
Tue, Aug 2, 2016 10:11 PM
Reply to cojhl2:
Its always been my understanding that its the sulfate build up in the bottom that kills the batteries.
Though I will admit to seeing a fellow take a dead 12 volt out of his Farmall H and shake it up and down to get a very cold tractor started one winter. (about 25 degrees F) He claimed it stirred up the denser cold acid with the water.
Following weekend (It was about 5 degrees F) I saw him I saw him take the same battery and turn it upside down on top of his truck battery (post to post) to quick charge it to crank the same H! Darn thing had enough to start and we had to work that day! :jaw:
Wed, Aug 3, 2016 7:34 AM
cojhl2
Reply to drujinin:
Saves buying Jumper Cables drujinin.
We were taught on cold mornings to turn on the lights for a few minutes before hitting the starter. Meant to warm the battery slightly.
Wed, Aug 3, 2016 8:02 AM
