Battery Box
Battery Box
Showing 1 to 10 of 17 results
dmgrow
Send a private message to dmgrow
 have spent time looking at parts manuals, pictures trying to solve this question. The parts book are no help.
What goes in the top three holes? This box looks like the one on my 5T 6V electric start pony. I am thinking the bottom three holes are for light switches that predate the rotary light switch found on the 6V U series electric pony tractors. The bolt pattern is odd being that the holes are not on a common center line. I had considered a master switch until I read you will damage the generator if you run the engine without a battery. I have yet to see a non direct start with a master Switch. I have considered a lamp, but both of my 9U have a dash light between the oil and temp gauges. Any ideas please. [attachment=68326]180460275_vintage-battery-box-caterpillar-crawler-tractor-d2-4u-5u.jpg[/attachment] [attachment=68326]180460275_vintage-battery-box-caterpillar-crawler-tractor-d2-4u-5u.jpg[/attachment]
Thu, Jul 7, 2022 12:45 PM
kracked1
It is for a lamp to see the switches and amp gauge.
Thu, Jul 7, 2022 7:34 PM
rax200
Hi dmgrow,
I have one of those boxes except for the light switches. The top three holes are for the starter switch (see photo) which consists of a bracket and switch used on the petrol series tractors
 [attachment=68327]20171101_163750.jpg[/attachment]
 [attachment=68328]20171101_163834.jpg[/attachment]
hope this helps
Thu, Jul 7, 2022 8:06 PM
3J1Bill
Reply to rax200:
Hi dmgrow,
hope this helps
Battery box on my CAT 22. Bill [attachment=68329]005.JPG[/attachment]
Thu, Jul 7, 2022 8:55 PM
jbernd56
Thank you received: 6
Reply to 3J1Bill:
I am working on a R2 and can those boxes be found anymore? Also can the switch be obtained still?
Thu, Jul 7, 2022 9:21 PM
Thank you received: 288
Reply to 3J1Bill:
Very nice battery boxes all of you folks. One day I will have a nice tractor to share. JM
Thu, Jul 7, 2022 9:23 PM
jbernd56
Reply to 3J1Bill:
3J1Bill, where did you get the starter button? Did you build your own box, or is one available still?
Thu, Jul 7, 2022 11:22 PM
3J1Bill
Reply to jbernd56:
Car swap meet for both parts years ago. Much easier with the internet now. Bill
Fri, Jul 8, 2022 7:58 AM
dmgrow
Reply to jbernd56:
If you just want lights that work and are not doing a resto, you can get a switch from cat. $60 bucks. The new switch is the same as a D5 with the round knob. It appears that the new switch will take the old style lever knob. The new switch does not have the dash light only selection. The dash would come on with the headlights. The second position turns on all four lights two front, two rear. If you have an old switch, it can be taken apart and cleaned up. Newer battery boxes in the U series have a auto reset circuit breaker. I plan to add one to each of my battery boxes. Be sure to calc the amp draw for the breaker if you have changed battery voltage or the number lights. The pics returned to my post are great. I have wondered about the top hole for some time. Still thinking there has to be a cutoff date when cat went from three toggle switches to the rotary switch. The basic box seems to have been used from 22s to U series (not confirmed). How about info for round top vs square top.
Fri, Jul 8, 2022 9:06 AM
jbernd56
Reply to dmgrow:
Thanks. I got a new original switch and light switches from Florin Tractor. Very helpful. Will be missed.
Fri, Jul 8, 2022 8:52 PM
Reply to jbernd56:
DMG: Are you planning on using two of the original CAT battery boxes for your D-6? Some of us just use a battery box from a later SA type machine, that will hold two 12V batteries. Whatever you do, I am sure will look good on your nice D6. JM
Mon, Jul 18, 2022 7:09 PM
