barbed push on, clamped hyd. fittings
Showing 1 to 10 of 12 results
Jim Davis
Send a private message to Jim Davis
Is there a trick to making it easier to push new braided steel hydraulic lines onto the barbed fittings?
I managed to get the tractor ends of two new hoses pushed on and clamped, but thought I would ask before tackling the cylinder ends. Would it help to heat the fitting? Heat the hose?
I spread some hydraulic fluid in the hose end before pushing/turning/jamming it on the ones I've done.
Hoping there's an easier way.
Jim
Fri, Jul 11, 2014 8:33 AM
If it's convenient, clamp the barb onto a cylinder etc and then you can more easily wiggle and push the hose so it basically crawls onto the barb.
Fri, Jul 11, 2014 9:50 AM
Hi Jim,
this fabricated hose press is what we used at The Dealer back in the day.
Fri, Jul 11, 2014 9:51 AM
Jim Davis
Barbs are all in position on tractor and cylinder. I guess it's just brute force, eh?
Fri, Jul 11, 2014 9:53 AM
Gary Morisoli
Send a private message to Gary Morisoli
Reply to Jim Davis:
Try putting the hose end in boiling water for a few minutes, dry it and spray WD40 in it.
Fri, Jul 11, 2014 10:31 AM
jmvmopar
Reply to Gary Morisoli:
Lube, lots of lube. Then brute force.
Fri, Jul 11, 2014 10:38 AM
mrsmackpaul
Reply to jmvmopar:
hydraulic is is not slippery or at least thats what I have always been told so, I was told to use engine oil for fitting off hydraulic hoses works much eaiser than hydraulic oil
Paul
Fri, Jul 11, 2014 10:49 AM
Jim Davis
Reply to mrsmackpaul:
Paul
OK. Thanks all. Tomorrow will try some heat and some motor oil.
Fri, Jul 11, 2014 10:57 AM
sr4440
Send a private message to sr4440
Reply to Jim Davis:
I took a block of wood and drilled a hole slightly smaller than the hose diameter then cut it in half.
Put rosin on it then I could clamp the hose in a vise. Used dish soap for lube and a plastic dead blow hammer. to help pound the fitting in. worked pretty well
Fri, Jul 11, 2014 7:05 PM
STEPHEN
Reply to sr4440:
The directions from edb said to use tire compound like Murphys. I have used grease and a large mallet.
Fri, Jul 11, 2014 8:55 PM
Old 3T lover
Reply to STEPHEN:
A liberal coating of 'STP' always seemed to work best for me....and on track master pins. Never used it in an engine.
Fri, Jul 11, 2014 9:15 PM
