Awakening a Holt 75 Engine from a Nap?
Showing 1 to 10 of 103 results
BigSkyTR6
Send a private message to BigSkyTR6
Thank you received: 26
Long time tractor enthusiast, first-time poster here. I need some help with awakening an old Holt 75 engine from a 2-year nap.
A little back story on the engine: (*placer holder for the year/serial number, additional info*). The engine is owned by our local tractor club and is currently mounted to a heavy steel frame. To be clear, the unit in question is the engine only, not a complete 75 tractor. The engine is complete forward of the flywheel. It has a belt pulley attached aft of the flywheel with an over-center clutch, but I am unsure if this is original. This engine was last running at least two years ago. At that time, the engine was very difficult to start and would cough, misfire and backfire frequently.
I have taken on the task of getting this Holt engine running again for our late-summer show/threshing bee. I am comfortable turning a wrench and doing basic- to moderate-difficulty operations. However, I have never worked on anything this old. I found a scanned copy of the operators manual for the engine online and have been studying it.
My plan for the engine was to start with a basic tune-up:
  1. Remove, inspect and clean spark plugs.
  2. Squirt oil into the decompression cups, priming cups and spark plug holes to get oil back on the topside of the pistons.
  3. Gently work the engine back-and-forth to get the cylinder walls coated in oil again.
  4. Verify while rotating the engine that none of the valves have stuck.
  5. Adjust all the valves. Per the operators manual, all should be 1/32" clearance, right?
  6. Oil all the rockers and the top end of the engine.
  7. Adjust point gap in the magneto. Note: I could use some help/instruction on this step. I have done point gaps in automotive distributors, but never a magneto. Also, per the manual, this gap should be 1/64", correct?
  8. Inspect/clean carburetor. Note: help with the carburetor would also be appreciated.
  9. Refill and apply grease to all the grease cups.
  10. ??? I am sure I am missing steps here...
Does anyone have recommendations on materials to read for working on this engine?
Are there any other systems or components (governor, mechanical lubricator, etc.) that need attention to awaken this engine?
Looking forward to this discussion!
Thanks in advance for the help,
Nick
Wed, May 6, 2026 1:40 AM
Bruce P
Thank you received: 33
Hi there. I wrote a nice long post of what’s causing your symptoms and what all to do, but the good old ACMOC site decided to throw a fit and it went away. I’ll reach out via the private message system and we can talk on the phone.
Regards
Bruce P
Wed, May 6, 2026 12:29 PM
Thank you received: 279
BP: So awesome of you to help this gentleman with their 75 engine. I hope they get it dialed in and share details about it soon. JM
Wed, May 6, 2026 1:44 PM
BigSkyTR6
Bruce P-
I look forward to your message and phone call. Thank you in advance for your time and assistance.
Nick
Wed, May 6, 2026 7:37 PM
Bruce P
Hi Nick. I sent you a message via the ACMOC private message system. It should pop up when you log in next, or you might have to click on the “in box” button.
BP.
Fri, May 8, 2026 1:48 PM
BigSkyTR6
Bruce -
It took me a bit to find it on mobile. I replied to your PM this evening.
Thanks!
Sat, May 9, 2026 4:27 AM
BigSkyTR6
I had typed up a long post to update everyone on the forum as to progress on the engine, but the forum ate my message…
I was able to get in touch with Bruce. He gave me a ton of tips and good advice on the engine. Many thanks again Bruce!
Short take and weekend update: crankcase opened over the weekend and doused in oil. Next, the top end of engine was disassembled and throughly cleaned. All rockers, pushrods and lifter cups re-lubricated with clean oil. All valve clearances adjusted per the book today. Rod bearings tested with a pry bar for play; all rods are nice and tight. With the valve clearances set, the crankcase oiled, and the spark plugs out, the engine rolls over pretty well now. Next up: carburetor and magneto!
Tue, May 26, 2026 3:36 AM
BigSkyTR6
P.S on the weekend update: here is a photo of the placard we display with the engine. It has a little history on the fate of the tractor and how we got the engine.
Tue, May 26, 2026 3:42 AM
Busso20
Thank you received: 30
Good to see the story behind the engine and now getting ready to fire up again after 108 years from casting
Tue, May 26, 2026 9:51 PM
Bruce P
Glad to help. Can’t wait to hear it bark.
BP.
Thu, May 28, 2026 2:28 AM
BigSkyTR6
Made some progress this weekend.  After a couple failures and buying some tools, I was able to get gaskets cut for the carburetor.
Using feeler gauges, I measured about 1/16” inch thickness for the gasket bore beneath lid (part “N” in the cutaway view in the operators manual.  The bowl perimeter did not originally have a gasket (and the cutaway doesn’t show one), but it looked like both surfaces were machined for one. I elected to create a gasket for this connection. I chose 1/8” cork for the carburetor throat/venturi ring and 1/16” cork for the bowl gasket.
I initially cut all new gaskets from cork. However, the gaskets that were on the engine from previous caretakers were Fel-Pro Karropak, so I also cut a couple gaskets for the inlet elbow and bowl-to-throttle body joints in Karropak.  Depending on how the cork rubber lasts, I may switch back to the Karropak.
I know gasket-making is pretty basic, but it’s another step toward getting the Holt running again.
Mon, Jun 8, 2026 5:07 AM
| Kingaroy, Queensland
