arizona proving grounds
Showing 1 to 6 of 6 results
steved73t
Send a private message to steved73t
my brother and I are making plans to attend CONEXPO in Mar. We willl be driving thru AZ, Where are the Cat proving grounds? Is it hard to get in to see anything?
Fri, Oct 1, 2010 4:27 AM
Kelly
steved73t,
Try Google..
Kelly
Fri, Oct 1, 2010 4:41 AM
chugwater crawlers
Reply to Kelly:
steved73t,
Try Google..
Kelly
It's south of Tucson near Green Valley. You can drive up to the main building,but you can't see much unless you are in a class there.
Fri, Oct 1, 2010 10:28 AM
Lou McMaster
Send a private message to Lou McMaster
Reply to chugwater crawlers:
Steve
Our local Caterpillar dealer should be able to make an appointment for
you to visit the Caterpillar proving grounds. Good luck.
Lou
Fri, Oct 1, 2010 8:47 PM
steved73t
Reply to Lou McMaster:
Steve
Lou
Thanks for the info. I need oil filters, so I'll check with the dealer when I get them
Sat, Oct 2, 2010 3:07 AM
veerCAT
Send a private message to veerCAT
Thank you received: 5
Reply to steved73t:
Its in Tinaja Hills
Sat, Oct 2, 2010 3:31 AM
chriscokid
Reply to veerCAT:
Its in Tinaja Hills
http://explorer.altopix.com/maps/?map=so9n8s
Sat, Oct 2, 2010 6:55 AM
| Kingaroy, Queensland
