Are there specs for when trac links should be replace?
daves2035
Send a private message to daves2035
I have a 5u,d2 cat. My rail or links are worn.I was wanting to know if there is a spec measurement when it has to be replaced. Also can the links be welded on to add material on, or if not, are they available. How thick are they when new? Thanks.
Mon, Jun 13, 2011 8:56 AM
go to crawler heaven for wear limits----http://www.crawlerheaven.com/index.htm
the rails can be welded on to build up but its labor intensive
Mon, Jun 13, 2011 9:13 AM
Reply to dpendzic:
Don't think you'll find these at Crawler Heaven but the measuring procedures are the same.
Mon, Jun 13, 2011 10:17 AM
BELLY
Send a private message to BELLY
Hi OM do have the same pecs for a D4 7U 1957 model ?
I d like to collect this information too!
Thanks in advance [Great Forum Too!!!]
regards Belly
Tue, Jun 14, 2011 5:39 AM
Reply to BELLY:
regards Belly
Ok OM--how about a 941b and D3b specs??😆
Thats real useful info that you have!
Tue, Jun 14, 2011 6:07 AM
Reply to dpendzic:
Well guys, I do have the info but it's not in a simple chart form like for the D2.
As the models progressed the options and changes got greater. Specs are different for spoked vs solid idlers, cast vs forged rollers, track links generally got taller with subsequent models. Pin and bushings sizes changed. Tracks evolved from dry pin to sealed to sealed and lubricated (not for the D4). Track bolting also changes, so to state the specs the track link part number and discription of the undercarriage components is required.
Here is some specs on the track links for the D4.....same as the 941B.
Tue, Jun 14, 2011 10:11 AM
