any tips for dozing dirt piles into a flat, hard packed surface?
Showing 1 to 10 of 12 results
Weekend Dozr
Send a private message to Weekend Dozr
I figured this might take some time but eventually I'd get the hang of dozing like the pro's. Not yet. I've got about six piles of 4-6 yards of free fill dirt all along the one side of my driveway. I'm dumping there to smooth out and bring that side level with the driveway. Currently it slopes down slightly and during our heavy snowstorms I've gotten stuck while plowing there a few times - plus a level area will improve the lot and allow more parking for more toys, (old dump truck may be next).
So I've pushed the piles back from the road good enough but as I've tried to doze parallel to the driveway the blade has gone high, and also dipped to low resulting from the tilt of the machine while driving over the uneven surface. I even have a place where I dug lower than the driveway which I must now fill in. At this point I had to stop yesterday when I found water in the transmission oil - will refill tonight and get back to it. I am getting best results now from pulling the dropped blade backwards. Is that how I should be working or do I just need to go slower and keep my blade even with the level I'm trying to keep while the machine keeps moving up/down? What a strong machine!
Tue, Sep 14, 2010 3:14 AM
sdakskinner
Send a private message to sdakskinner
What you are descibing is a common affliction for new operators. We have all gone through it. Some of us still do the dip and dive on occasion. Just keep trying and you will learn to anticipate what the dozer is up to. Your finish work should be to backdrag with the dozer. Give it time and before long you will be a good operator. Best of luck on your project. Marty
Tue, Sep 14, 2010 3:46 AM
Cysco
Reply to sdakskinner:
I have very little experience on a dozer as well. I have learned that if you can keep the blade closer to "full" than not it will push much better. Then do the back drag to smooth. I know some wince at the thought of back dragging but untill I get better it is a necessary evil for me...... 😊
Have a good day....Bill
Tue, Sep 14, 2010 4:57 AM
Reply to Cysco:
to see some of the better operators on there with a small tractor. The biggest trick with a D2 is to think about 3 or 5 feet ahead of only one corner of the blade. You don't care about the other corner, it follows the one you are watching.
Where you are grading on a right of way you want to stay a little higher than it. Start on the edge of the pile, go straight out, back up, move over to cut a little more of the pile, push it out. The bigger part of the pile will fall down as you work across it. Back dragging is acceptable but SOME people say never do it. I can grade with a D2, BUT I do OCCASIONALY backdrag too! It covers up screw ups! Anyways when you are looking out a ways in front of you instead of intently trying to adjust and stare at the whole cut. You end up jerking the blade up and down. If you do a long cut and get a bump in it where you raised the blade for whatever reason. Back up to that mistake and start your correction right there going only farther enough to straighten it up or back drag the fill back over the mistake and level it into the point just prior to where you raised the blade and made the bump. Too many guys are continously trying to raise and lower the blade like a high speed, high pressure hydraulic system attached to a laser. Another thing is half throttle and first gear is plenty fast enough. Practice, practice! Patience, patience! You are not going to buy a tractor, jump on it and start dozing like a pro. It took a lot of years for the good operators to get good.
Jeff
Tue, Sep 14, 2010 7:25 AM
D6c10K
Send a private message to D6c10K
Reply to drujinin:
Jeff
I haven't got many hours on a dozer either and I agree that it's probably best not to back drag all the time, but what else is the "float" position on the lift control for?
Tue, Sep 14, 2010 8:01 AM
jbernd56
Thank you received: 6
[quote="Weekend Dozr"]I figured this might take some time but eventually I'd get the hang of dozing like the pro's. Not yet. I've got about six piles of 4-6 yards of free fill dirt all along the one side of my driveway. I'm dumping there to smooth out and bring that side level with the driveway. Currently it slopes down slightly and during our heavy snowstorms I've gotten stuck while plowing there a few times - plus a level area will improve the lot and allow more parking for more toys, (old dump truck may be next).
So I've pushed the piles back from the road good enough but as I've tried to doze parallel to the driveway the blade has gone high, and also dipped to low resulting from the tilt of the machine while driving over the uneven surface. I even have a place where I dug lower than the driveway which I must now fill in. At this point I had to stop yesterday when I found water in the transmission oil - will refill tonight and get back to it. I am getting best results now from pulling the dropped blade backwards. Is that how I should be working or do I just need to go slower and keep my blade even with the level I'm trying to keep while the machine keeps moving up/down? What a strong machine![/quote]
all good advice so far. One more tip I might throw in is to remember that whatever slope or angle the tractor is setting on is the angle or slope that the blade will want to make. If you can get a good flat spot started, then always go back to there before making another pass in the loose dirt. You will be packing the already level spot and not as apt to make so many dips and dives. Backdragging is always a good way to smooth things out and clean up grouser tracks. A lot of high speed backing will eventually wear out the pins and bushings on the back side. Everybody always roaded the machines backward simply because they didn't like to eat all the dirt!
Tue, Sep 14, 2010 8:36 AM
cojhl2
Reply to jbernd56:
Gosh!! I never had a problem with dip and dive especially with a 4 roller D2😆
Seriously, In my limited experience with a blade the pointers in this thread are valuable to me.
Thanks Weekend Dozr for starting this thread
Tue, Sep 14, 2010 11:16 AM
ol Grump
Reply to cojhl2:
About the only time I use the float position is winter when I'm shoving snow around on an already iced or packed road. I've tried it a few times on a fairly hard surface moving dirt but it seems that if a rock gets rolled under the blade it tends to bounce up and over it.
Tue, Sep 14, 2010 8:39 PM
Dandy Dave
Send a private message to Dandy Dave
Reply to ol Grump:
When I first started Bulldozing as a young feller, I can remember the old boss on the job telling me not to backblade because it wears the heads off of the cutting edge bolts. Every once in a while I would catch him backblading though, I know he had at least 20,000 hours running a D7-E plus many other machines. Funny thing was that we always had to tourch the bolts out anyway when it came time to change the cutting edges. The other thing is to work in multiple angles where there is room. If you can attack the job at 120 degree angles that will fill in some of the bumps that were created on the previous passes and after a while everything just fills in once you have a handle on the blade. Keep in mind that the best machine for road work is a Road grader. You will never get it as good with a Bulldozer as you can with a grader. Dandy Dave!
Tue, Sep 14, 2010 9:35 PM
timbo1946
Send a private message to timbo1946
Reply to Dandy Dave:
While not the best operator I can manage to do a OK job. Full blade is easier, muliple passes moving side to side, or at angle does help. I have run a D6D for a few days, and it was a much easier tractor to run than the D2. If a wash board starts sometimes it is better to stop, back up and start a new pass. Here a a few pics of a parking area I put in for my brothers winery. Pushed off the top soil, and spread 5" to 6" bank gravel. Yes I back bladed to finish.
Thu, Sep 16, 2010 6:58 PM
Reply to timbo1946:
Snow on frozen ground is the only time we ever really used the "Float" position. It was a real chore getting the blade low enough to push snow but not dig up the roadway on the initial pass! When I was out in the "Oil Patch" of PA, we always plowed the Oil Lease roads with a D4's and D6's. One year Pennzoil hired a Backhoe operator with a big truck plow on the front. The claim was he could plow faster and cheaper, plus he took more snow off and less dirt. The other place we used "Float" was if we had the tractor on a cleared lot for a home, then we backdragged in float. But other than those times, we never used it much.
Timbo did a real nice job on that parking lot, first pealing the topsoil, second on spreading the gravel even though he said he finished it by backblading. I would too as that is a high visibility project where lots of people will see result.
Where jbern noted about whatever slope or angle the tractor is setting on is the angle or slope that the blade will want to make. I have a LaPlant Choate "Trailblazer" blade on my tractor which has "Armstrong" tilt and angle allowing me to start the blade on the slope I want. Then manually adjust it for the rest of the passes which makes you think a couple of cuts ahead so as to not be climbing on and off constantly adjusting the tilt and angle!
As far as packing it down, a dozer is not the best at packing because the tracks distribute the weight over a large area. Which is why a couple of weekends ago I knocked a road through the woods on a project that I left the downhill side quite high as rain and winter will settle that dirt till its no longer higher than the uphill side of the roadway.
Fri, Sep 17, 2010 2:57 AM
