Any ideas what these are for?
Showing 1 to 10 of 15 results
bicicat
Send a private message to bicicat
I have attached a photo of the plates welded on my D7E track frame. I have no idea why they were fitted. I am restoring the tractor and if they have an interesting history I will not cut them off. They are fitted to the outside (as shown) and the inside of the track frame and also to the chassis rails. The trunions as far as i can tell have never been used and they are only welded on with no bolts. My guesses are either pipelayer, crane or armour mounts but it would be nice to know.
Thank you for looking.
Fri, Jul 24, 2009 4:56 AM
Gordon.
Send a private message to Gordon.
They could be pipe layer brackets. If the machine was a pipe layer it would probably have a non occilating equaliser bar, have a check to see what it looks like. if you dont want the brackets on the tractor i would cut them off and tidy her up. Does seem strange that the blade trunnions are welded on.
Regards Gordon.
Fri, Jul 24, 2009 5:22 AM
bob
Send a private message to bob
Reply to Gordon.:
Regards Gordon.
That's what they look like to me aswell Gordon. That's the side the counterweights and drums are mounted on. That tractor has an equilizer bar but I wonder if the carrier roller support might bolt on where the hard bar once did. They might have used good frames from a pipelayer on that D7. If the support was in the right place all you would need to do is weld on diagonal braces.
Later Bob
Fri, Jul 24, 2009 8:27 AM
bruce oz
Thank you received: 21
Reply to bob:
Later Bob
hello bicicat ,are there the same brackets on the other side ? ,i could have been a farm tractor with ammonia tanks for cotton ,bruce oz
Fri, Jul 24, 2009 8:39 AM
Gordon.
Reply to bruce oz:
Mornin.... Seems strange having that trunnion welded there.
Bob i think even pipelayers need to have diagonal braces do they not ? Would you not still need suport for either the backend or trackframes ?
Regards Gordon.
Fri, Jul 24, 2009 12:32 PM
bicicat
Reply to Gordon.:
Regards Gordon.
Hello and thank you for your replies. the plates are identical on both sides of the tractor. The equaliser bar does swing but that could have been changed at some point. Could the plates welded to the chassis done the same job with maybe a linking piece bolted in?
Fri, Jul 24, 2009 1:52 PM
bob
Reply to bicicat:
Most of them don't have have a diagonal brace Gordon. They have a very strong hard bar across the frames and it's very close to the point of max load.
Later Bob
Fri, Jul 24, 2009 6:23 PM
Gordon.
Reply to bob:
Later Bob
Yep we learn something new every day.....well i do anyway.Lol I remember a guy who bught an IH BTD 20 he did not know that it was an ex pipe layer fitted with a blade, a non tilting angle blade at that !!! i think some modifications had to be made after levelling proved to be a little awkward.
Regards Gordon.
Sat, Jul 25, 2009 3:24 AM
AJ.
Send a private message to AJ.
Reply to Gordon.:
Regards Gordon.
I would say the brackets are for a pipelayer,the reason the trunnions are welded on directly to the frame is because the trunnion mounting plates have been removed to make room for those brackets or were never there in the first place,the trunnions did not bolt directly to the frame,there was a heavy thick plate welded to the frame that the trunnions bolted to,there should be a couple of inches of the frame showing under the trunnion,they are mounted now lower down than they should be.
AJ
Sat, Jul 25, 2009 6:39 AM
bosco
Send a private message to bosco
We had trunnions like these on our 7E and 7F for a Holt root plow.
Sat, Jul 25, 2009 8:34 AM
AJ.
Reply to bosco:
Not easy to find a picture of the mounting of the trunnion on a standard dozer,but I did.
AJ
Sat, Jul 25, 2009 2:43 PM
