Any idea about this blade on a D4 5T?
SkyMoCo
Send a private message to SkyMoCo
I picked up this D4 5T the other day and the blade seems very cobbled together and off some other larger Cat.   Any idea on it, I'm thinking I'll just leave it off and not bother with it.
Thu, Jun 13, 2024 12:24 PM
Thank you received: 53
Hi, SKyMoCo.
I'm gonna stick my neck out here and say basically Isaacson crossbred with DIY.
But eye dew stand too bee kee-wreck-ted - to quote the immortal Swishy.
Thu, Jun 13, 2024 1:24 PM
Thank you received: 27
Hi, SKyMoCo.
That is copied after a Bucyrus Erie blade in the way the arms and low pressure high volume hydraulic cylinders are built. Also one of the early blade building companies used the springs to limit down pressure on the blade, that was not B&E. Until someone goes back and digs up the post that in my mind was only months ago (so it could of been years) were we listed the many names of companies that built dozer blade and had pictures I will say Deas has as good a guess as any.
I would say all but the blade itself looks very original to me. And without more pictures I would not say the blade is from something bigger. It could just be a lot of added stuff that a over egger handy man thought would improve his dozing ability.
Thu, Jun 13, 2024 10:19 PM
Mike Meyer
Reply to Ray54:
My D4 2T here in Australia had the almost exact same blade set up.
Fri, Jun 14, 2024 1:51 AM
Reply to Mike Meyer:
Hi, Ray54.
I'm gonna disagree with you here. I'll BET that the lift link with the spring around it in photo #1 is NOT 'very original'. There is NO WAY that it came from the factory bent like that. LOL.
If my memory serves me rightly, Isaacson did make a blade lift system very much like the BE system but with fabricated lift arms instead of cat steel like BE.
Just my 0.02
Fri, Jun 14, 2024 5:41 AM
