any 12 volt starters on pony
Showing 1 to 10 of 25 results
captainhowdy
Send a private message to captainhowdy
just a quick question. dit ma cat put any 12 volt systems on the d4 U series pony engines
Fri, Oct 13, 2017 1:01 AM
No, not that I am aware of. The 6V units will run fine on 12V if you don't crank them to death and it is harder on the bendix springs. They are Delco Remy motors which probably could be converted to 12v by changing field coils and armature and possibly shafts.
Fri, Oct 13, 2017 1:25 AM
captainhowdy
Thanks Magnet. the previous owner has installed a 12 volt battery, has this damaged my charging circuit? all of the components are there and i woild like to get a 6 volt batt.
Fri, Oct 13, 2017 2:31 AM
Reply to captainhowdy:
It helps to install wider brushes in the 6 volt starters for better cranking.
Fri, Oct 13, 2017 3:16 AM
captainhowdy
everything is complete including the VR. the starting motor works fine and the pony starts right up no problems. has the 12 volt batt done any damage to my charging circuit ?
Fri, Oct 13, 2017 3:32 AM
cheshire cat
Send a private message to cheshire cat
Not likely ,it would just not charge as the regulator is set to cut out out at about 7 volts ,
putting a 12 volt battery on is a sure sign the person hasn't a clue about basic electrical repairs
as these delco motors work really well on 6 volts if the battery and the cables are all good and the motor is ok....
Fri, Oct 13, 2017 4:14 AM
captainhowdy
Reply to cheshire cat:
anybody know what the group number is for the original battery? crank amps etc???
Fri, Oct 13, 2017 5:14 AM
8C-3629 675CC $118.55 From Cat
Fri, Oct 13, 2017 5:39 AM
$118 isn't a bad price, I think the NAPA 675CCA in my John Deere B was right around the same price (a year or 3 ago)?
Fri, Oct 13, 2017 7:52 AM
captainhowdy
Reply to drujinin:
thanks all!!! i am going to get a group 2 6 volt and see.
Fri, Oct 13, 2017 9:03 AM
restore49
For what it is worth - have been using 12 v with original 6 volt pony starter for 40 years with no problems.
Fri, Oct 13, 2017 7:50 PM
