Anti-seize can brushes errr! lol
Showing 1 to 10 of 14 results
Anyone have trouble with these brushes breaking off after awhile? Well I went and got an old tooth brush and stamped a round hole in the cap and pushed the brush through. Works great, gets the anti-seize in the bolt threads better too. Used a brush that was narrow in the middle and larger towards the ends.
Tue, Feb 10, 2015 8:32 AM
bryani289swmi
Send a private message to bryani289swmi
Rome/KG,
I've recently started using one of the bolt dip applicators and like it. Seems to be less mess and doesn't overapply like I usually do. Thanks.
Bryan
Tue, Feb 10, 2015 8:57 AM
Reply to bryani289swmi:
Rome/KG,
Bryan
Usually mine start getting dry and the bristles start flattening out.
Thanks for the tip!
Tue, Feb 10, 2015 9:20 AM
Thank you received: 19
Reply to drujinin:
Thanks for the tip!
I throw those brushes away, punch a hole in the lid and use solder flux brushes or sometimes called acid brushes.
Tue, Feb 10, 2015 9:26 AM
Jack
I don't why you bother. Isn't there something in the directions that says you are supposed to get that stuff all over every exposed inch of your body when using it? It just seemed to me that a crummy applicator was necessary for proper application. Was I misinformed???
Tue, Feb 10, 2015 11:25 AM
Thank you received: 44
Reply to Jack:
Hi, ROME/KG.
I'm disappointed in you, M8. After all the helpful and informative posts that you have put up here showcasing your knowledge and inventiveness, I would have at least expected you would set up an ELECTRIC toothbrush.
LOL.
Wed, Feb 11, 2015 3:09 PM
kracked1
Hi, ROME/KG.
LOL.
Anti-seize is one thing that when you call to order it you get it on your ear!
Wed, Feb 11, 2015 8:03 PM
Reply to kracked1:
Lol Deas! ya its messy enough without it flying off the brush. It's like some greases takes a weak to get it washed off your hands. If the anti seize does get dried out just add oil to it and mix.
Wed, Feb 11, 2015 8:44 PM
D6c10K
Send a private message to D6c10K
The only thing more messy than anti-seize is prussian blue....always end up wearing it for a couple of days
Wed, Feb 11, 2015 9:07 PM
Reply to D6c10K:
Isn't that what they put in porta-jons? lol
Thu, Feb 12, 2015 8:27 AM
yancy44 mag
Send a private message to yancy44 mag
hay guys your all going about this all wrong i use marvel mystery oil and the foam brushes you get at the big box hardware stores but every one has their own go go juice good luck🤘
Thu, Feb 12, 2015 9:05 AM
Earlcoate Charity Open Day
