Another run of 20 and 30 manifolds
Showing 1 to 10 of 12 results
ianoz
Expressions of interest .
Due to a request for these parts .Another batch will be made .
Post up here if anyone needs them .
Sun, Aug 9, 2020 1:14 PM
Hotrod392
Send a private message to Hotrod392
I’d be potentially interested in an intake for a big Twenty.
Cat Ten
Cat Twenty
Cat Sixty
Cat D4
Cat 66 Grader - hand controls
Sat, Aug 15, 2020 5:15 AM
ianoz
Reply to Hotrod392:
Hi Hotrod , Will check to see if inlet manifolds are being done , and will get back to you .
Sun, Aug 16, 2020 2:49 PM
ianoz
Reply to ianoz:
We are Re-Running the Cat 20, Cat 25, Cat 28, Cat 30, Cat 35/40 and CaT R5 Manifold Projects Again !! Anyone on ACMOC Forum Interested in joining in ???
Sun, Aug 16, 2020 2:50 PM
ianoz
Reply to ianoz:
Cat Radiator Supports V-62 Available
Sun, Aug 16, 2020 3:06 PM
hfdzl
Reply to ianoz:
How about heat valves for 22?
Sun, Aug 16, 2020 3:22 PM
ianoz
Reply to hfdzl:
Sorry Herb , unfortunately the 22 is not on the list for parts remanufacture
{Wally } Brewzer seems to be the go to man for second hand 22 parts ,Check what Wally can help you out with .
Sun, Aug 16, 2020 3:50 PM
Skidmarc
Send a private message to Skidmarc
Reply to ianoz:
I’ve just picked up a 1928 L series twenty. Both the intake upstand pipe and intake manifold aswell as the exhaust manifold are a bit worse for wear. Depending on price to to NZ I would be keen. Thanks
Sun, Aug 16, 2020 4:31 PM
hfdzl
Reply to Skidmarc:
Just asking, plenty of 22s around.
Sun, Aug 16, 2020 10:33 PM
Thank you received: 78
Reply to hfdzl:
Not many with good manifolds unfortunately. I built mine up in a tedious manner using mild rod and gas, just to get a bit of thickness in there and fitted a juicy thick gasket to keep it gas-tight.
Mon, Aug 17, 2020 2:53 AM
cletracker
Send a private message to cletracker
Reply to ianoz:
Might be interested, have a 25 with bad manifolds. Do you know the price range?
/Erik
Mon, Aug 17, 2020 11:14 AM
