another crazy pony thought/question
Hillbillybjopkr
Send a private message to Hillbillybjopkr
first off.....are the head gaskets reusable on mine...s/n 7U23655....also.....I have this spray stuff...that's suppost help with stuck ring and to help recondition the top end....its a foam spray you put in through the sparkplug hole....let it sit for a bit....then turn the motor over a few times....let it sit some more....then start it.....do you think this would be a good idea
Mon, Oct 2, 2017 3:22 AM
most of the D2 and D4 pony motor head gaskets are reusable---the foam is a good idea but after it soaks and you spin it over a bit you may want to check the compression and see if the rings are somewhat loose----also the valves
Mon, Oct 2, 2017 4:21 AM
Hillbillybjopkr
Reply to dpendzic:
so....I put that foamy stuff in....and after fighting the pony...ALL DAY...(starter teardown and clean up)....it fired up and ran....like normal....was able to get the main engine started....do what I needed to do...and park her......next to the shop......im tired of fighting the pony.....more like the pony's carb.....ok......just the whole thing period lol...and.....I need another project....
Mon, Oct 2, 2017 9:52 AM
