American Bosch rotor resurfacing?
doggman
Send a private message to doggman
I noticed in a thread that suggested that the rotor could be resurfaced. My D6-9U MJK mag is giving me a fit and I thought I’d try to salvage what I have before I order new parts.
What’s the recommended procedure for resurfacing that rotor? Thanks, Craig [attachment=57623]B04A4EAF-0F4E-4E53-A5E7-4CD797C2F9A0.jpg[/attachment]
Thu, Mar 12, 2020 1:09 AM
ag-mike
[quote="doggman"]I noticed in a thread that suggested that the rotor could be resurfaced. My D6-9U MJK mag is giving me a fit and I thought I’d try to salvage what I have before I order new parts.
What’s the recommended procedure for resurfacing that rotor? Thanks, Craig [/quote]
I been wondering too, hate breaking brushes! urs is alot worst than mine.
Fri, Mar 13, 2020 7:21 AM
STEPHEN
Reply to ag-mike:
I've never tried this, but I would make an arbor and grind on the surface grinder in a spin jig.
Fri, Mar 13, 2020 10:29 AM
naylorbros
Thank you received: 26
Reply to STEPHEN:
I have cleaned up Eisemann G and GV rotors on my lathe. I have used very light cuts, and have not been able to take very much off as the metal is not overly thick. Also with the Bakelite being softer than the brass or what ever Bosch used the metal will be a little proud of the bakelite. I have taken care of this with a light sanding with a fine sandpaper on a flat surface. With all of that being said your rotor looks sad.
Ken
Fri, Mar 13, 2020 8:36 PM
Tad Wicks
Reply to naylorbros:
Ken
It is fortunate that Cat parts are readily available, in cases where they are not, a rotor like this could be duplicated from Delrin (Acetal). It may not be cheap but it can be done and should last a lifetime.
Sat, Mar 14, 2020 11:10 PM
bursitis
Reply to Tad Wicks:
fill the cracks with epoxy and then use a piece of thick glass with some fine grit wet dry paper in a figure eight pattern. go slow and make the grit finer in steps until you are done.
Sun, Mar 15, 2020 1:45 AM
