American Bosch Batteryless Generator
KenP
Send a private message to KenP
Looking for any info on American Bosch Batteryless Generator Model # ARKF130/6-000L. Have one in my shop that appears to be missing wires coming out of Generator to Light Switch/Voltage Limiter Relay unit. All Generator componets to check OK but came in without Field Wires connected to Light Switch/Voltage Limiter Relay. Thanks KenP
Fri, Jan 9, 2015 9:17 AM
Thank you received: 63
I have the info on the generator. Can you make out the color of the wires coming from the generator? The blue & yellow leads combine to a single wire going to the regulator coil with the switch coming off the junction. The white & red leads combine to a single wire that goes to what looks like a buss strap on the regulator.
I'd post the wiring diagram but I'd have to dismantle a manual that is about six inches thick to be able to scan.
Fri, Jan 9, 2015 10:42 AM
cr
Send a private message to cr
Thank you received: 25
here you go
Sat, Jan 10, 2015 1:17 AM
KenP
Reply to cr:
here you go
Thanks for the info & pics. Got the unit wired up correctly but still does not operate. Do you have any resistance specs for Field Coils? I have 2 ohms resistance through Blue & Red & 7 Ohms between White & Generator Field Case. I suspect that the Regulating Resistance Field Coil is bad. Any info & specs on this Generator would be greatly appreciated. Thanks Ken P
Sun, Jan 11, 2015 2:32 AM
mrsmackpaul
Reply to KenP:
if you were to seperate the red and white and test from the blue and yellow to the white you should have a circuit if and you should also have a circuit from red to the blue and yellow
if you dont have a circuit between white and the blue and yellow but do between the red and the blue and yellow it would tell me you have either
a faulty resistor
a faulty brush or brush holder
a faulty armature
if you dont have a circuit between red and the blue and yellow but you do between the white an the blue and yellow it would tell me you have a faulty field winding
I would suspect either a brush is stuck in its holder or a brush is worn to the point it is no longer contacting the armature as these are the two most common faults in gennys
hope this is of some help
Paul
Sun, Jan 11, 2015 4:18 AM
