alternator on d8 2u
alternator on d8 2u
boots
Send a private message to boots
wanting to put a gm alternator on my 2u wondering if the motor turns fast enough going to use the generator pully off the cranksaft small pulley behind the water pump belts and mount in there some how also what wonld cause some wear on the outside of track pin bosses not bad just a little noticeable wear track bushings that the sprocket contacts are not even worn at all thanks boots tracks not snaky at all thanks boots
Thu, Jun 4, 2015 6:52 PM
7upuller
Hey Boots,
Here is a link to OldMagnets picture of my 17-a alternator setup. I purchased it from Dana @ Florin Tractor. It's a simple setup, works great. Look at second picture in first post on thread.
http://www.acmoc.org/bb/showthread.php?23039-Santa-Margrita-Pics
Thu, Jun 4, 2015 7:36 PM
Thank you received: 51
Reply to 7upuller:
Hey Boots,
In the day I used to see Cats show up at a down town Fresno used parts seller's place with a belt drive set up.Not as neat and clean a set up as pictured but it worked. The generators had been gutted and the shaft sticking out the back end of the case with a pulley and mounting brackets welded to the generator case.The pulley size can be adjusted to get proper speed for your alternator.
Thu, Jun 4, 2015 8:19 PM
Reply to Ray54:
If its an older 10SI or next generation 12SI, then a "Low Speed Turn On" Voltage Regulator is available as I did some research on this subject a couple of weeks ago.
Fri, Jun 5, 2015 3:26 AM
