all most to embarrassing to ask
Showing 1 to 7 of 7 results
plowboy1982
Send a private message to plowboy1982
Just got my first cat home and only way i can get it to turn is to push on what I am calling a break and pull on leaver at the same time is this right or is something wrong with turning clutch 1939 R2
R2 6J
Thu, Sep 5, 2013 11:18 PM
dandawn79
Send a private message to dandawn79
My D4 7U does the same thing LOL and thats the way they turn your good to go. Someone with more knowledge can tell you more in depth how that works but yours is working as designed.πŸ‘½
Thu, Sep 5, 2013 11:45 PM
plowboy1982
Reply to dandawn79:
OK Lol thank you I have been around a lot of old equipment except a cat so just wanted to make sure that was correct the man I bought it from never used it or even start it butt had the nerve when I arrived to load it how I was going to load it and said well I'm going to get it started and drive it on and he replied looking I'm sure that I'm young and have long hair said do you even know how Lol well I checked for spark put some gas in hand primed fuel pump chocked it twice third pull on crank it sat there and ran Lol should have seen his face it took me bit to figure out how to steer it but I drove it right on to the trailer
R2 6J
Thu, Sep 5, 2013 11:57 PM
Reply to plowboy1982:
the lever you are pulling back on releases the steering clutch on that side--thus reducing the drive power to it. depending on the slope you are on it will sometimes steer a little that way--applying the brake stops the brake drum that is connected to the sprocket and track
Fri, Sep 6, 2013 12:17 AM
And if you ever are being pushed by a load or going down a steep slope, when you pull a steering clutch, the load may push the tractor around toward the opposite side. In that case, you can use that to your advantage to make the turn in the direction you want, or just pull the usual clutch like you do on flat ground and use the brake extra heavy.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare timeπŸ˜„
Fri, Sep 6, 2013 12:47 AM
Someone else just asked this a month or two ago and one of the replies had a section of the operation manual of a tractor scanned in?
It better explains the issue of going up and down hill and/or towing a load.
Two cases where the foot brake is not necessary.
Typically going down hill you would pull the opposite lever for slight turning corrections as the weight pushing you will speed up the normally dead(non-powered) track.
Clear as Mud? πŸ‘
Fri, Sep 6, 2013 12:56 AM
plowboy1982
Reply to drujinin:
Clear as Mud? πŸ‘
Makes complete sense I wondered if that's how it worked so if you are to pull back on both clutches at the same time you should be able to stop all movement of the machine correct?
R2 6J
Fri, Sep 6, 2013 1:24 AM
all power will be removed from the tracks and if on level ground machine will come to a stop
Fri, Sep 6, 2013 2:21 AM
