Alaska D6 9U #1
Alaska D6 9U #1
Showing 1 to 10 of 18 results
Ron A.
Send a private message to Ron A.
I have a D6-9U Serial #9U28590 that has a hydraulic blade, manual angle, manual tilt. I would like to put a hydraulic tilt on it (climbing on and off isn't as much fun now as it was 40 years ago). Any suggestions as to where I should look for an assembly to accomplish this? Thanks.
Ron A.
Sun, Apr 8, 2018 3:12 AM
Thank you received: 64
Nothing available commercially that I know of. That's something you will have to shop build. Choice of belt drive pump off the fan belt or off the generator drive. Doesn't take a very big pump, some get by with power steering pump.
A few have tackled the job on here but info is pretty sparse.
Here's one in a video.
https://www.bing.com/videos/search?q=caterpillar+d6-9u+videos&qpvt=caterpillar+d6-9u+videos&view=detail&mid=AB578E746F20D935E899AB578E746F20D935E899&&FORM=VRDGAR
Sun, Apr 8, 2018 11:55 PM
Or install a two valve #44 hyd unit from an Ht4.
Mon, Apr 9, 2018 12:05 AM
That would be way overkill for a tilt cylinder that only needs a few gpm.
Mon, Apr 9, 2018 12:27 AM
steeltracs
Thank you received: 10
Is it possible to install a priority valve in the hydraulic circuit for the tilt ram?
Mon, Apr 9, 2018 12:35 AM
D4C Charlie
Send a private message to D4C Charlie
Reply to steeltracs:
One of my cat books show a diverter valve for using a ripper, seems possible for a tilt cylinder too.
Mon, Apr 9, 2018 2:39 AM
Joel59
Send a private message to Joel59
Reply to D4C Charlie:
I went with the belt drive power steering pump setup. It works great. These guys helped me through the process a few years ago.
Mon, Apr 9, 2018 7:11 AM
Reply to Joel59:
Hi Joel59,
Could you post some pictures of your tilt conversion?
Mon, Apr 9, 2018 8:09 AM
Ron A.
OK. Thanks everyone.
Ron A.
Mon, Apr 9, 2018 9:54 AM
Joel59
Reply to Ron A.:
Ron A.
I realize it is a pretty crude setup. Put it has served me well so far!
Tue, Apr 10, 2018 11:11 PM
Joel59
Reply to Joel59:
here is the cylinder
Tue, Apr 10, 2018 11:18 PM
