my 10K D6c parts book shows a couple different numbers....early 1m7250....late 6h8021
- not sure those plastic bodies are the same as yours
-i'll take a look on mine and see if the numbers are there
Thanks kittylover for the informtion. Look in the original post. I edited it and added the measurements. What you have is about the same size as the one on my 9U D6. I guess we can rule out the 6H8021 as too big. The 955 is a D4 chassis. This one is 7 1/8 inches in diameter at the top outside, 6 5/8 inches at the bottom and 3 inches tall on the outside. The inner cone is 3 5/8 inches in diameter and 4 inches tall. Cat gave the measurements for 1M7250 which are 10 1/2 inches outside, 5 7/8 inches inside and 4 inches tall, which makes it too big also.
yes Brian, i think you're 100 percent correct and on the right track....somebody out there must have the number!
Go to a farm machinery dealer and enquire for Donaldson pre cleaner bowl. Readilly available in Australia and should be in other countries. My D6R has one factory origional and other manufacturers still use them.
got to your nearest eh bare and company (bareco) or sparex stockist. they have plenty of them there is only 4 sizes. cost about 20 bucks most tractor dealers stock bareco or sparex parts.
