AI Moderator issue
AI Moderator issue
Showing 1 to 10 of 10 results
Deebo
Librarian
Thank you received: 74
Hi guys,
I just had to approve 17 flagged posts, none of which should have been tagged so I’ll inform the website team there’s been this issue! Thanks all for your patience. Constant tweaking required by the look of it.
Regards,
Tony
Sat, Jun 28, 2025 11:51 AM
Thank you received: 152
Thank You Tony! It appears AI is the culprit on the red flagged postings from what you found. Maybe AI should go away and the other problems will too? AI does not seem to listen to the complaints or provide the fixes, those of us out here in the dirt and dust rely on you, and your plate runneth over! It is no small wonder so many of us antiques balk at this so called improvement to our systems.
Thanks for posting the information. It helps many of us as we tend to believe the problem is with our systems or devices when in fact it is the website.
Along the same lines - the Juiceman's posting of "let's see some action photos" illustrates the continuing issue with attaching photos or video to a post. This issue needs fixed. AI guilty here too?
CTS
Sat, Jun 28, 2025 1:05 PM
Thank you received: 244
Thank you Deebo. Very frustrating to say the least. We realize you and others have your hands full. Let's hope the new website gets dialed in soon. I have plenty of show photos to share and some new members would like to use the site as well. JM
Sat, Jun 28, 2025 1:13 PM
brian18a
Thank you received: 52
still all new posts not visible
Sat, Jun 28, 2025 2:27 PM
Flagged for review!!! Again!
Sat, Jun 28, 2025 3:11 PM
Photo's are not working again - can not post - only results in the Icon showing. Reading an existing post - never know if it will take you to first entry or last - seems to depend on the post?
A new member just tried to post - imagine his thoughts when trying to post photos of his "new" acquisition. HANG IN THERE! The team is working on the issues.
Sat, Jun 28, 2025 4:41 PM
Deebo
Librarian
The team are on it!!
Sat, Jun 28, 2025 6:03 PM
Busso20
Thank you received: 21
Deebo, could you have a look at the 'for sale' appears the top items are having the same issue of replies in the header page and no extra posts when the item is opened, Naylorbrother temp gauge and diggerman pony parts.
Sun, Jun 29, 2025 12:31 AM
Deebo
Librarian
Will do, thanks Busso20!
Sun, Jun 29, 2025 8:23 AM
Thank you Deebo...now we can post away. JM
Sun, Jun 29, 2025 2:21 PM
I will happily second that THANK YOU "deebo". Without your vigilance and help, we would be sitting here frustrated.
Continue working the problem, certainly a solution is obtainable. CTS
Sun, Jun 29, 2025 4:59 PM
