Stephen.
I recently re sleeved a corroded bore on a vertical starting engine .Total cost was about $50 for the sleeve and several 6 packs to share with my neighbour.
Who owns the boring machine. Sleeves are un finished . You final bore them to 5tho. over piston size.
Cost effective will depend on if you are buying new parts or re using old pistons, access to your neighbors boring machine etc.
Measure every thing to see if it is within spec.
A lot of these engines are already sleeved, in which case they can be either bored out and the sleeve replaced or bored oversize.
The attached photos have been posted in a previous post..
Hope this helps.
Andrew...K...![]()
Hi Stephen, I had a D2/D4 pilot motor sleeved by a engine shop last year and it cost $150 for one cylinder, there is a company here in Oz who make new pistons for your pilot motor and I've bought them too, they were around $US100 each for the piston, rings, gudgeon and circlips and are available up to 80 thou oversize, you just tell them what size your bore is and they machine the piston to suit, they have a good reputation. Google JP Pistons Adelaide Australia, I just got home last night from a week over there and will be back over there within a month or three I'm sure, it's about 400 miles west of me, if I can help don't be afraid to sing out.
Regards
Mike
Hi Stephen, I've also bought pistons from JP and they shipped them to me here in NY very reasonably. They worked perfectly and I'm very happy with them (this is on my D2 pony)
G,Day Mike ,
Ya could have saved your money and done the boring job here. Only would have cost 3 or 4 cartons.
Andrew... K....
Added some unrelated photos for your enjoyment......................![]()
Nice loading ramp Andrew! : )
I'll keep that in mind for the future Andrew if I need any boring done. I could supply my own machinist if need be. Lol. That loading ramp looks like a bit of a short notice knock up good idea.
Yeah you would be most welcome. My neighbor Cornie, has an amazing array of equipment and enjoys nothing better than seeing like minded people
getting some use from it.
And yes that was not a good day. Finished up in a real mess.The truck kept going down deeper. The more we tried to dig it turned into soup.
There is a video of the day but I haven't worked out the U tube thing yet.
Cool cool 👍👍👌
