Adjusting Steering Clutches D8-8R
Showing 1 to 10 of 10 results
firekat
Send a private message to firekat
Hello
The problem is the left steering clutch will not disengage. But it was working a couple of days ago,now nothing. Does anyone know how to check or adjust the linkage properly. The only time I can get it to work is in low reverse pulling the lever and brake on. help please😕
firekat
Tue, Feb 3, 2009 11:07 AM
Here are the adjustment instructions.......a place to start but may be a more serious problem.
Tue, Feb 3, 2009 11:08 PM
steved73t
Send a private message to steved73t
The throw out bearing went on my 3T D7 The lever was loose with little resitance. Is your lever still feel normal pull?
Tue, Feb 3, 2009 11:43 PM
firekat
Reply to steved73t:
the lever feels like there is freeplay from where it sits say to about 12 o'clock then I start feeling resistance then the lever is right against the seat frame. Is there any keys at the bottom of the lever. The parts book doesn't show anything.
firekat
Tue, Feb 3, 2009 11:59 PM
Reply to firekat:
firekat
Yes, there are six keys at various locations on the cross shaft.
Wed, Feb 4, 2009 4:01 AM
firekat
It has been awhile for me to get a chance to actually take it apart. Once it was apart and cleaned up, I noticed that the keyway has expanded to almost 3/8" wide. So what do I do? Weld up the bore and start filing or get a good used bracket? (2B929) part of the left steering clutch lever.
thanks for your help
firekat😊
Mon, Feb 23, 2009 1:57 PM
gwhdiesel75
Reply to firekat:
firekat😊
OM, where did those adjustment instructions go?
Mon, Feb 23, 2009 7:52 PM
Reply to gwhdiesel75:
GWH,
Due to the imposed limitations on picture files it is required that previous pictures be eliminated to provide more. Penalty for not having archives and such limitations. Also a very big PITA to not be able to post a legible full manual page of information (293kb).
Ya, I know you can post using a host site for pictures but that just doubles the effort for the user. Sorta gave up on this ever evolving but since you asked......
I can re-post the instructions if there is a need.
Mon, Feb 23, 2009 10:52 PM
GWH,
firekat,
Those are some of the options.....
Depending on the size of the boss it may be possible to bore the end out and replace it with a keyed collar....sorta like a bushing only with keyway.
Also may be able to cut the whole end off and replace it with a similar section from something with similar (good) end.
or...weld the whole thing up and do the machining over.
Mon, Feb 23, 2009 10:59 PM
firekat
firekat,
Thanks OM
I will try to get another one off a machine.
firekat
Mon, Feb 23, 2009 11:58 PM
elhoffman
Send a private message to elhoffman
Reply to firekat:
Thanks OM
firekat
[quote="firekat"]Thanks OM
firekat[/quote]
HI FIREKAT I GOT A NEW 2B929 L.H.BRACKET FOR YOUR CAT AND ANEW 8B1053 R. H.BRACKET FOR YOUR STEERING PLUS A LOT OFF OTHER PARTS FOR 8R AND 2U CATS AND I LIVE IN KELOWNA BC IF INTERESTED EMAIL ME AT e.l.hoffman @ shaw .ca. 0r phone me 250 7655881 . ERNIE.
Tue, Feb 24, 2009 4:17 AM
