additive needed for diesel??
Showing 1 to 10 of 10 results
NIK O.
Send a private message to NIK O.
friend/partner thinks low sulphur offroad diesel lacks lube for pump & injectors, about 1980 vintage 504 size diesel, turbo. do i need to add 2=stroke oil to my fuel?
be blessed, grateful, prepared, thanx, nik viet vet
Tue, Oct 21, 2014 7:04 AM
Jw74
Send a private message to Jw74
I have never heard of doing such a thing and have run off road diesel in equipment for years you can add special stuff specifically for diesel fuel to keep from jelling up in the super cold and to provide a little extra cleaning power for the injectors if you want but I would not ad oil to it. Its called off road only because it is not taxed for on road use. hope this helps
Thanks God Bless
Tue, Oct 21, 2014 9:00 AM
ronm
Reply to Jw74:
Your friend's info is out of date...when low-sulfur fuel first came out, it did have lubricity problems, especially for distributor-type pumps, like Roosa Master. The other problem was that it leached the oil out of o-rings & seals, causing them to shrink & leak. That problem has been remedied, fuel suppliers caught enough flak that they added lubricity to the fuel. A fuel conditioner won't hurt anything, but it's not as necessary as it was for a while there...Your 504 (Case)? probably has a Bosch inline pump, which is not as susceptible to lubricity problems anyway.
Tue, Oct 21, 2014 9:45 AM
Reply to ronm:
That about sums it up...
Neither engine manufacturers, 2-stroke oil producers nor lubrication engineers recommend adding oil at this point.
Tue, Oct 21, 2014 10:04 AM
gclare55
Send a private message to gclare55
Reply to ronm:
The only additive I have used is a biocide to prohibit algae in long standing fuel most times you will not need. If you use any biofuel be prepared for major fuel problems had Ford F600 regularly change filter, three times clean fuel tank clean fuel lines etc. switch back to regular diesel no more problem. Currently work on D8 for Museum Fuel has been it for better than a year ( I like to keep it full or near full ) no problem, it doesn't get the work out it used to to much building around us but at least we are on leased county land so we are good for now. respectfully Gary
Tue, Oct 21, 2014 10:06 AM
mrsmackpaul
Reply to gclare55:
do blokes have summer and winter fuel in the states? Summer fuel in Australia has more wax and if used in winter the wax freezes or maybe just goes thick but stops the motor running anyway
Paul
Tue, Oct 21, 2014 10:11 AM
Yes, there is winter and summer blended diesel here in the US and Canada. Basically #1 diesel (more like kerosene) blended with regular #2 fuel to lower the cloud point.
Most of the time, the fuel suppliers take care of switching over what they are supplying, but if someone has their own large tank and is keeping lots of fuel on hand, they can get out of sync with the seasons and have problems. Usually there are lots of problems when exceptionally cold weather hits early in the winter and not everyone has a tank full of winter blend and has not changed fuel filters in preparation for winter etc. There are more diesel "daily driver" vehicles than there used to be, so lots of folks that don't know how to prepare for cold weather fuel related problems. If they are filling up at the local station on a regular basis, they don't have to know much about it. But, when it really gets cold, even the knowledeable diesel operator can get caught with gelled fuel/plugged fuel filter.
Tue, Oct 21, 2014 9:29 PM
Newbie
Send a private message to Newbie
G'Day Gents,
Here in Western Australia, the fuel suppliers don't considder it cold enough, on average, to need them to supply winter fuel. So they don't...... It's not much fun for me, as I can go a week (with a few odd days thrown in here and there) where I can't run anything diesel at home. I just happen to live in a bloody cold spot. Nearly everyone else is fine. 😞
Phill.
1937 RD4 - 4G7191
Thu, Oct 23, 2014 9:34 AM
ronm
Reply to Newbie:
G'Day Gents,
Phill.
Newbie,
Just get some PowerService or something similar, a pour-point improver. Should help your summer fuel problem...or just add a little kerosene. Is # 1 diesel available there?
Thu, Oct 23, 2014 11:07 AM
Thank you received: 78
Reply to ronm:
Newbie,
If you do doctor your diesel, make sure it won't invalidate any warranties that you might have.
Thu, Oct 23, 2014 6:26 PM
cojhl2
While living in IA with 4 diesel vehicles (Kids and Wife driving) I always provided a few small bottles of Power Service for them to carry with instructions to add full bottle to tank when filling with fuel. I did this regardless whether the supplier had winter blend.
Cost so little and prevents jelling, (which is a big prob at 20 below and engine stops out in the middle of nowhere)!
Thu, Oct 23, 2014 9:47 PM
