add a water heater to d-4
cfbromm
Send a private message to cfbromm
I have a D-4 ( # 24270} and want to a water heater. I found one opening on the lower radiator hose. Looking for a place for returning to the radiator system.
Sat, Dec 31, 2022 1:42 AM
rax200
Hi cfbromm,
The other outlet or inlet is the drain on the engine block
Regards
Sat, Dec 31, 2022 3:34 PM
kracked1
Reply to rax200:
Hi cfbromm,
Regards
The block drain makes a good inlet for your tank heater. On my 7U there is a small 2 bolt block off plate in the thermostat housing. It is on the same side as the fuel filter housing. That plate can be removed and a pipe bung welded in. That makes a good return as it is at the head level and will circulate through most of the whole engine. Make sure you follow directions on mounting the heater.
Sat, Dec 31, 2022 8:40 PM
| Kingaroy, Queensland
