Actually pushed some stuff around today
Showing 1 to 6 of 6 results
Hdonly
Send a private message to Hdonly
Decided that it was time to actually push some stuff around with my D6B today. First time running a cable blade direct drive machine. WoW, a fella can get mighty busy with all these levers. No time for a cup of coffee and a cigarette while running this thing. The cable blade is working really well, I think it just needed using. I am by no means an operator yet though. That will sure enough take some serious practice. I was very surprised that the crack in the block has healed itself. Still going to shine the metal up and reapply some fresh JB Weld to it. I bought a carbide rotary file for my die grinder. Still have to take the throttle mechanism apart and see why it won't stay put. Oil pressure stayed above 25 psi with water temps in the low side of the green. Brakes, steering clutches, flywheel clutch-brake and forward-reverse all worked without any issues. I could sure use a third arm and hand though-haha Lots of small things to do to it yet. Thank you all for all the help and information.
Wed, Feb 6, 2019 7:29 AM
Layne
Send a private message to Layne
The seat on these is pretty wide, I was thinking about having my wife drive with me and operate half the levers. After thinking about that for a minute, pulling 10 levers by myself didn't seem so hard anymore. 😄
Wed, Feb 6, 2019 8:05 AM
Hdonly
Reply to Layne:
Ha ha ha. I'm kinda wide myself and no wife to ask for help. But i'm with you, that probably wouldn't be such a good idea. You know what they say about women drivrs. No, I didn't say that!
Wed, Feb 6, 2019 8:25 AM
Thank you received: 140
Reply to Hdonly:
Hi, Hdonly.
Yep, there a few things to keep you busy onna stick shift cable controlled dozer. One tip that you may find helpful regarding the actual dozing part of it all - try focussing on keeping the blade where you want it to be and using the information gathered by your eyes and the feel of the seat under your 'favorite rump steak' to tell you what you need to do to keep it where you want it. Anticipation is a big part of this but usually only comes with practice.
Some people laugh at this idea but it does work. Every time you are driving it from point to point, try 'shadow dozing' - keeping the blade as close to the ground as you can without letting it touch. This will help you to understand what your eyes and your butt are telling you about what the machine is doing on the ground that it is passing over.
Wed, Feb 6, 2019 8:59 AM
Inter674
Hi, Hdonly.
With a cable blade ALWAYS chase the blade up otherwise you might end up with the blade crashing down n busting the cables eg when backing off wind rows.
Wed, Feb 6, 2019 9:30 AM
Hdonly
Reply to Inter674:
I figured that out today, keeping the blade close but not on the ground trying to see just how much the blade moves in relation to changes in the ground.
As for chasing the blade, I kinda figured that out after crashing to the ground when backing away from the debris pile. Didn't bust any cables, but I can sure see how it happens. I can see that this cable blade needs a lot of my attention. I had some of you on here tell me about quick bumps on the blade control instead of trying to feather it up and down. Even when I'm not on the dozer and just sitting around thinking about it, I try to remember all the tips that you real operators have given me.
Wed, Feb 6, 2019 9:49 AM
Reply to Hdonly:
Hi, Hdonly.
A LOTTTTA people don't realize that, once you know which controls do what and where they all are, you CAN do some 'practising' in your mind by just thinking about them, what they do and where they are and any the sequences in which you might use them. F'rinstance, you might notice that you push the forward reverse FORWARD to go into reverse and you pull the main gearbox lever BACK to change from first into second. With this in mind, you can 'program' your mind to make a U-shaped movement when you want to change from 1st forward to 2nd reverse, away from you with the forward reverse lever and back to you with the main box. It doesn't take long for it to become automatic.
Yep. you never try to 'feather' a cable control - quick 'bumps' up or down - and practise following the blade up when it rises as you push into a windrow of trees, etc..
Just my 0.02
Wed, Feb 6, 2019 10:33 AM
