Accessory shaft seal
Showing 1 to 7 of 7 results
unstyled
Send a private message to unstyled
I am in need of the accessory shaft seal part number 4B4865 for my 1946 D6 5R that goes in the fuel filter housing. I called Cat parts department yesterday, they said that particular part number is no longer valid/not available but are supposed to get back to me with a replacement part if one is available. I'm not sure if one can or will be found. Does anyone know where I can locate this OEM part? I ordered this seal off the internet from an aftermarket manufacturer a couple weeks ago, it was nowhere near the quality or correct dimensions as the original, which is quite worn out. It was destroyed installing - the diameter was just a little oversize (and cheaply made) I've run into this problem before with non OEM aftermarket parts sometimes. I have googled this part number but found only cheap, overseas aftermarket junk so far. Thanks for any help you can give.
Wed, Sep 13, 2023 2:46 AM
bruce oz
Thank you received: 19
??? https://www.ebay.com.au/p/703088203
Wed, Sep 13, 2023 3:38 AM
Reply to bruce oz:
4B4865 crosses to a National/Federal Mogul/Timken #450171
Plenty of them out there.
Wed, Sep 13, 2023 3:51 AM
unstyled
Reply to bruce oz:
That is the EXACT seal I was referring to. Slightly oversize and cheaply manufactured. The OEM is so much more robust but thanks anyway!
Wed, Sep 13, 2023 6:17 AM
Reply to unstyled:
Cat has the 1H5959, formerly 4B4865 , specs. O.D. 2.254, Shaft Dia. 1.438, Width 0.500
Wed, Sep 13, 2023 6:30 AM
Might try one of these places for an original...
https://www.machinerytrader.com/parts/search?PartNumber=4B4865&SearchType=Start
Wed, Sep 13, 2023 6:32 AM
unstyled
Now that looks like the part I'm after. Ordering it asap, Thanks again!
Wed, Sep 13, 2023 7:23 AM
unstyled
I found 2 original Cat OEM seals from Old Magnet's website he found, bought them both at $5.57 each!
Thu, Sep 14, 2023 8:47 AM
Newby Hall Tractor Fest
