A tad too much wear.
Showing 1 to 10 of 20 results
Newbie
Send a private message to Newbie
G'Day Gents,
Something I noticed when I was dragging the RD into the shed on Sunday, was a bit of wear on the swinging drawbar. :faint: This will hopefully teach everyone to lock their swinging drawbar into one position.
I think my RD has a few hours under his belt. I can't see this much wear happening otherwise. I suppose what really gets me is the fact that the wear was either never noticed, or it wasn't considered to matter.
I will pull the drawbar, cut out the warn section, and weld in some new plate. Unless I replace the support/guide bar, there is no way of repairing that... Will I suppose I could bild it up, but the distortion would render it useless.
Phill.
1937 RD4 - 4G7191
Fri, Nov 28, 2014 5:32 PM
gauntjoh
Librarian
Thank you received: 8
[quote="Newbie"]G'Day Gents,
Something I noticed when I was dragging the RD into the shed on Sunday, was a bit of wear on the swinging drawbar. :faint: This will hopefully teach everyone to lock their swinging drawbar into one position.......
Phill.[/quote]
Hello Phill,
Actually when you are pulling for example a trailed plough or set of discs, the drawbar should definitely not be pinned but allowed to swing. The drawbar is pivoted under the middle of the tractor and allows easier steering when the drawbar is not pinned. If you try and plough with a pinned drawbar steering will be much harder and cause more wear on steering clutches, brakes etc.
Having said that, there should be a sacrificial wear plate between the swinging drawbar and the drawbar quadrant, when this wears down it should be replaced, take a look in your parts book.
Fri, Nov 28, 2014 6:23 PM
Thank you received: 140
Reply to gauntjoh:
Phill.[/quote]
Hello Phill,
Hi, Newbie.
Gauntjoh has said, almost word for word, for what I was thinking as I read your post. The drawbar swings for a reason.
Just my 0.02. (Apparently, Gauntjoh's too.)
Fri, Nov 28, 2014 7:13 PM
Newbie
Hi, Newbie.
Gents,
What I meant to say, but didn't due to rushing, is "when you're not using it". I have seen tractors with similar problems and they have only spend 0.01% of their time using the swinging drawbar. The rest of the time it swung from side to side with no load. But perhaps that is a different situation as they tend to move so much faster.
If that is strictly worn from use, then it certainly got some use. Don't they get some grease applied to reduce the wear? Or does it get scraped away too fast?
No matter what, I have some repair work to do.
Phill.
1937 RD4 - 4G7191
Fri, Nov 28, 2014 11:42 PM
7upuller
Reply to Newbie:
Gents,
Phill.
Hey Newbie,
The Drawbar does show wear, but I've seen a lot worse. I realize your posting name states "Newbie", but I suggest you start your tractor and drive it before painting, decaling, and detailing it. I don't know how many tractors you have, or how many you have driven, but I suggest you listen to others who give you their time and experience. Guys like Deas and John have much experience and always try to help. glen
Sat, Nov 29, 2014 1:31 AM
Lance Jones
Reply to 7upuller:
Hey Newbie,
Hi Newbie , Agree fully with Deas and John , You will note that the drawbar pin has little wear , indicating to me that operator always Used Correct size drawbar Pin ,with little Float between the pin Holes ,You see many ,if fact majority I suspect of Early Cats with badly worn or distorted drawbars because I suspect of Bad Mounting and Pinning . You only operate a fixed drawbar when you have something like a drawn Harvester [Combine to Our US friends ] or something with a PTO drive . it is essential to have a Swinger for easier Turning and saving of Steering Clutches and Brakes . It is necessary however to use a Fixed Drawbar when travelling on Road Etc. with Higher Speeds [Wheel Tractors particularly ] for Safety as a machine could easy get the Wobbles' Up and Cause an Accident . As mentioned Cat Supplied Expendable wear plates on their Machines to Eliminate wear Problems , of which I have a couple Units with them still fitted .LJ
Sat, Nov 29, 2014 2:20 AM
Reply to Lance Jones:
Hi, Newbie.
Applying grease to a swinging drawbar on a crawler is akin to applying straight grinding paste, just a TINY bit slower. It amalgamates with the dirt thrown up by the tracks and STAYS there, thus ACCELERATING wear.
Sat, Nov 29, 2014 2:53 AM
STEPHEN
Hi, Newbie.
Newbie, here is a thread about the shoe I made, look at the pic there. From memory, the early RD4 did not use them, I looked at my RD4 & it looks like a shoe would fit there no problem, more so if there is a space opened up like you have.
http://www.acmoc.org/bb/showthread.php?19809-D4-drawbar-shoe-made&highlight=
Sat, Nov 29, 2014 4:50 AM
cojhl2
Hi, Newbie.
Just to add fuel,, we always ran a swinging drawbar unless as others have said, pulling a combine or any other implement that may run over you on a downhill run.
We always had in addition about a 2ft extension on the drawbar. Of course most of our equipment was cable drawn, except for plows, disks, and drills. So the extension kept the big triangles away from the tracks. But even with implements that had a tongue we never removed the extension. Now that I think of it the extension was only removed for the combine.
Sat, Nov 29, 2014 4:57 AM
7upuller
Reply to cojhl2:
Hey Newbie,
I was taught and have read in a Cat comic ad, that a scraper in tow should be pinned. Most Ag applications should swing. I enjoy the comic teachings from Cat from years past. glen
Sat, Nov 29, 2014 6:14 AM
josh
Reply to 7upuller:
Hey Newbie,
Could you just turn the drawbar over?
Sat, Nov 29, 2014 6:19 AM
