A new 5U D2 addition
Showing 1 to 10 of 11 results
brian18a
Thank you received: 69
This arrived today, I bought believing I could get it running, had been parked outside since 2018. A friend delivered it today. He said seller drove onto trailer, was a pleasant surprise. It is converted to direct electric start long ago. Put batteries in it and started instantly.
Thu, May 21, 2026 12:53 AM
brian18a
Thu, May 21, 2026 12:54 AM
Thank you received: 288
Congratulations Brian! That is a clean little orchard rig. I like the custom hydraulic reservoir and the fenders are not clapped out like many. I just picked up an orchard D2, but not as lucky as you. I am sending the magneto out to be freshened up. Mine is 14,xxx from Santa Rosa, CA.
Your are a tall person; are you going to move the seat back and up for some leg room? JM
Thu, May 21, 2026 1:56 AM
brian18a
Yes seat adjustment is necessary. I can't get my feet on the brake pedals. this is 18xxx 1956 vintage. The owner made the hydraulic system for all of his tractors.
Thu, May 21, 2026 3:22 AM
GrantJ
Thank you received: 10
Being in the 18000 range, it probably came with the bellhousing already drilled to put a starter. I have 18314 and it came from the factory drilled.
Thu, May 21, 2026 3:29 AM
Waiting it’s turn. Of the 4 brought home, I expected this one to start easy. I was wrong!
Thu, May 21, 2026 5:09 AM
Thank you received: 77
I admire the thought process that went into the location and design of that hydraulic tank
Thu, May 21, 2026 12:21 PM
seyser
Thank you received: 60
Very nice!
Thu, May 21, 2026 1:24 PM
Online
Thank you received: 214
Photo deceiving? The back rest appears to be inside the seat ring? No spring, that is a sure way to expect some extra pains and aches. I sympathize with the Big Feet and Long Leg issue on Tailseat D2, operator comfort was not considered nor was ease of mount, dismount. - CTS
Sat, May 23, 2026 2:34 PM
I could not help notice your steering levers are turned around. I am guessing they could only do that after the fenders were removed. On my "Courtland" D2, it has slop in the levers. One day I would like to remove the "rack" and either bush the levers or shim them. Perhaps drill and tap for grease fittings as well.
That is a really nice D2. Out of curiosity, how close to the end of production was that one? I remember the parts machine that you had purchased from here; it was very close to the final build. There are a couple of very late ones near me as well.
It might be time for me to have some more cushions made for the orchard tractors here. I will experiment with a seat and try my luck at using it as a template to make new seat railings as well. If "SandMan" still has any, I just soon buy some from him.
It is no secret that as we get older, the orchard machines are easier to climb on/off of too! JM
Tue, Jun 16, 2026 1:46 PM
brian18a
It is 714 from end of production. I have a parts top seat that is 721 from end and your late one is 67 from end
Tue, Jun 16, 2026 3:16 PM
