I finally got the clutch plates made and riveted on. I had the center plate surfaced 10 months ago and it has taken me that long to get to the clutch plates.
Ken
Nice job - it looks like you were able to locate the material then cut your own? Finding anyone to cut lining and drill, rivet is probably another of the long lost arts. Thanks for sharing - cts
Part of my delay was trying to decide what to do on the lining. The parts book lists is as 1/8” thick but the print shows 5/32”. 1/8” is readily available from several sources. 5/32” was a little more difficult to find. The proper countersink bit was not cheap. There are cheap ones all over the internet but they make a flat bottomed hole where there is a slight taper on the bottom of the correct style bit. The correct bit also has a replaceable carbide insert bit and a nice depth stop built into it. I can not wait to try it on brake band linings.
