A Few K-Rails To Go Around
Showing 1 to 10 of 28 results
Paso Bob
Last week I answered an ad that stated, five K-rails free if you come pick them up and haul them away. I was lucky enough to be the first responder. Tom and I made a quick trip to check them out. All were in good shape and were exactly what we each have been looking to acquire for some time. However they were in the ground fairly deep as they were retaining some landscape. So a plan was developed which included Dwight's lowbed to haul Tom's Cat 966 over and extract them. I ended up with one , Tom took two and Dwight took two. Everyone won, the homeowner got them removed and he fully understood after watching the 966 work that it took the correct equipment and expertise. The 966 was dancing a bit with the back wheels airborne a number of times pulling them out of the ground.
When I unloaded mine, my old forklift didn't have the capacity to pick up the whole K-rail, so my Ford skip and drag had to help and it lifted just enough to drive the trailer out from under. They are going to put to use making loading ramps.
[attachment=50287]IMG_5820.jpg[/attachment][attachment=50288]IMG_5825.jpg[/attachment][attachment=50289]IMG_5826.jpg[/attachment][attachment=50290]IMG_5830.jpg[/attachment]
Mon, Aug 13, 2018 11:49 PM
in new england those are called Jersey Traffic Barriers as New Jersey was the first DOT to design and use them
Tue, Aug 14, 2018 12:46 AM
Thank you received: 288
Reply to dpendzic:
Good score guys. I’ve been shopping for good, slightly used K rails here; about $250.00 to $800.00 each depending on quantity. Pays to have the proper equipment too. Enjoy. JM
Tue, Aug 14, 2018 1:17 AM
Crawler Dollars
Reply to dpendzic:
Funny...I watch 'Highway Thru Hell' and the Canadians call them 'No Post' rails.
Tue, Aug 14, 2018 2:33 AM
Reply to Crawler Dollars:
yea--I guess every body calls them something different for sure---when you want zero deflection on a vehicle hit they are cast with holes in the lower "flange" to drive posts thru--every guide rail and traffic barrier has a defined allowable movement--cable barriers being the largest and these being the least aside from a pored concrete wall
Tue, Aug 14, 2018 2:44 AM
Reply to dpendzic:
Ouch! a little strain on the ole 445 there!
Tue, Aug 14, 2018 4:07 AM
janmeermans
Paso,
I see you even prevailed on Dwight to do the loading. I guess you were the Super. and Tom was the Project Mgr. Good team work never the less. Your 445 would not have left the ground had Deas been in the seat! 😊
We need a couple of those for a ramp at Vista museum.
JanM
Tue, Aug 14, 2018 4:25 AM
Reply to janmeermans:
Paso,
JanM
I like to lift heavy items from the end of the loader beams there at the bucket pins.
Tue, Aug 14, 2018 9:32 AM
Paso Bob
Jan, that me laugh at loud! Poor Deas... And now he is really wanting to become a Californian for some reason.
Rome, good point. I will do that next time. I just purchased that 445 recently and am learning it's tricks. So far I'm pretty impressed with it.
Tue, Aug 14, 2018 10:31 AM
Crawler Dollars
Paso,
JanM
[quote="janmeermans"]Paso,
JanM[/quote]
Here you go Jan... https://inlandempire.craigslist.org/tls/d/rail/6623006009.html
Tue, Aug 14, 2018 7:28 PM
JanM[/quote]
Crawler$$$. I’d like the pretty one on the bottom please. Could you pay the man $75 and deliver it to me too please? If you help unload it, you can buy me lunch too........
Tue, Aug 14, 2018 8:48 PM
