A couple of D7E questions
Showing 1 to 9 of 9 results
farmerfred
Send a private message to farmerfred
[attachment=50240]IMG_1911.jpg[/attachment][attachment=50241]IMG_1910.jpg[/attachment]
Did Caterpillar start their serial numbers at Number 1 or Number 501, like all the farm implement companies did? Mine is 874, so I'm just wondering how near the first it was. My second question: Is this a factory cab from Cat or an after market cab? I've been told both by "so-called" experts. Can't find a serial number or a tag of any kind on it. And I've never seen one like it.
Wed, Aug 8, 2018 9:22 AM
greengiant
Send a private message to greengiant
nice tractor!
where is your serial # located? I can't find it on my E. I assumed it is now covered by the added rear Hyster.
Wed, Aug 8, 2018 9:56 AM
Thank you received: 57
Reply to greengiant:
nice tractor!
Interesting cab style - almost like one of those old-school D9 cabs. I think most serial # ranges started with 1 but there were some exceptions. Someone here will have some examples I'm sure
Wed, Aug 8, 2018 7:09 PM
my research shows that the D7E models-47A,48A,79A,and 95A all started with serial #'s 85 or 159, depending on model
Wed, Aug 8, 2018 7:55 PM
Reply to dpendzic:
1961 47A00874. That would be another manufacturer cab. The serial number should be on the engine block just above the starting engine transmission hi-low gear shifter, if electric start then above the starter. You can get service and operating manuals from Cat or on ebay.
Wed, Aug 8, 2018 8:24 PM
Thank you received: 39
All D7E models start out at #1.
Wed, Aug 8, 2018 10:44 PM
I got that info off IronRecord---guess its not too accurate!
Wed, Aug 8, 2018 10:56 PM
Reply to dpendzic:
Several sites seem to make use of the "Toughquip" Caterpillar Equipment Buyer Information Guide which is chuck full of errors.
Wed, Aug 8, 2018 11:16 PM
catsilver
Most Cat serial numbers started with #1.its just that the first few were sometimes 'seed' machines put out with customers for testing.
Thu, Aug 9, 2018 12:43 AM
seiscat
Reply to catsilver:
Hello farmerfred, as others have stated Caterpillar serial numbers always start at 1. I could see the master clutch lever in photo 2 so your machine is a direct drive, your serial number is 47A874. D7E 47A1 through 47A3395 are the low horse(160hp). Please note that the inner sprocket hubs for the 160hp D7E are no longer available from any source new and are VERY rare used. Proper maintenance of the final drives and sprocket bearings is critical.
I suggest it is a good idea to obtain the correct manuals for your tractor from ebay or other sources.
I also noted that your tractor is equipped with a No. 171 Hydraulic Control which is for a tilt cylinder on a Cable Control blade.
[attachment=50245]2018-08-08 11.38.33.jpg[/attachment] [attachment=50246]171 hyd control.jpg[/attachment]
I purchased the manuals in the pic from ebay also check the For Sale/Wanted section of this site.
Craig
Thu, Aug 9, 2018 1:46 AM
