A call for help again Adjusting Valves on D4 6U
57jacob
Send a private message to 57jacob
can anyone tell me how to adjust the valves on a D4 6U i have the service reference book. But im not finding it in there or what is in there is not very descripitive Can anyone please help?
Wed, Feb 6, 2013 8:09 AM
Run tractor to get it to operating temp, stop engine and remove hood and
valve cover. Next remove cover over timing marks on flywheel and turn engine to one of the two TDC marks. They are numbered 1&4 and 2&3. One of the two cylinders listed will be at TDC of the compression stroke. Usually both the rocker arms will be loose on the cylinder you will adjust and one or both valves will be open with tight rocker arms on the one you can't. Adjust the intake and exhaust to 0.010" clearance. Note that you can release the compression to turn the engine easily, but don't forget to switch back to RUN before adjusting.
Turn engine 1/2 turn and adjust another cylinder.
Repeat
Wed, Feb 6, 2013 8:47 AM
d9gdon
Just roll the engine over until one of your valves opens and adjust the intake/exhaust that's still closed. If your intake valve is open, your exhaust valve has to be closed on that cylinder and vice/versa, no magic on these D315s. Set them to .010 hot. I set mine to .012 when it was cold cause I had it apart.
Wed, Feb 6, 2013 8:50 AM
57jacob
Reply to d9gdon:
Ok thank you both your replys sounds simple enough and very helpful.
Wed, Feb 6, 2013 9:12 AM
57jacob
Reply to 57jacob:
pretty much the same way i adjust the valves on our mack trucks except 2 more cylinders. and they have different settings for the intake and exhaust not the same clearance..
Wed, Feb 6, 2013 9:17 AM
BillWalter
Reply to 57jacob:
All 4 cycle engines, except 3 or 5 cylinder, have pistons that have a running mate----153624 take the last 3 cylinders and move them under the first three 153
624 So one and six are running mates and so on. When you see an exhaust valve close, you'll then see an intake open while rolling the engine over in direction of rotation. At that time you are near TDC, go to opposite cyl and set the valves both at the same time. You can start on any cyl. Example, you see #two exhaust closing and the intake opening, set vales on #five. When I was a young pup, I used to write the firing order on side of manifold so I could keep it all straight. Works Great!!!
Thu, Feb 7, 2013 6:32 AM
Newby Hall Tractor Fest
