A BIGGG Turnip Digger.
Showing 1 to 10 of 23 results
Thank you received: 99
Hi, Folks.
Here are some photos of the D8 8R fitted with the Howard rotary hoe that is part of the Bert Thiess collection which is to be moved holus bolus to the Ipswich Railway Museum.[attachment=32446]DSCN0935.jpg[/attachment][attachment=32445]DSCN0907.jpg[/attachment][attachment=32444]DSCN0906.jpg[/attachment][attachment=32443]DSCN0905.jpg[/attachment][attachment=32449]DSCN0922.jpg[/attachment][attachment=32448]DSCN0933.jpg[/attachment][attachment=32447]DSCN0925.jpg[/attachment]
Enjoy.
Sun, Dec 6, 2015 7:58 AM
janmeermans
Deas,
That is a interesting machine and is the largest rototiller I have ever seen. I can't quite feature how the tines are driven but it must be direct mechanical drive through the rear of the transmission. The hydraulic pump only serves the lifting rams correct?
With that tiller hanging off the back, that D 13000 looks like it wants to leave the ground and fly!
Jan
Sun, Dec 6, 2015 11:02 AM
Reply to janmeermans:
Deas,
Jan
Hi, JanM.
It's kinda hard to get a good shot of the drive with the hyd. pump above it like that but, yes, the hyd. system only raises and lowers it. Here is another photo with a slightly different angle that gives a bit of a glimpse of the drive shaft.
[attachment=32456]DSCN0923S.jpg[/attachment]
(My Gawd, Jan. The things I do for you. I had to reduce that photo THREE times, from around 3500 X 3000 megapixels down to around 2700 X 2100, to get it to load here. LOL.)
I didn't count them but I would not be surprised if there has been an extra leaf added to the equalizer spring 'cos, like you said, it sure does sit up and take notice.
There is this jigger made by Fowler In England that would certainly rival the D8.
https://www.youtube.com/watch?v=wK3ca1JTjyk
That link will probably come up with a few more links to other videos of the same and similar beasts.
Sun, Dec 6, 2015 11:56 AM
old-iron-habit
Hi, JanM.
Hi Jan,
I have the little bit smaller American version in my yard. I bought it with the clutch out. I have the new clutch and plan to get it back in next spring. I did make sure the 4-71 screamer would run last fall when it followed me home. This one is a Hillman Tiller. They were mainly used to pulverize old asphalt and mix new asphalt for a few years doing a better job than rolling the gravel with oil added back and forth with a grader. Then the hot mix plant became popular and these tillers went on the wayside. This one has two transmissions, one for the tiller, and one for the machine, and has 3 different style sets of teeth came with it for different applications such as grinding hard asphalt, making new asphalt, and there is one set for grinding up brush. My owners manual says that for 3" diameter brush and down they recommend you simply drive over it and pulverize it instead of cutting it first.
The picture has nothing to compare size in it but the front tires are 10:00 twentys and the back tires are near 6' tall. I wonder how big of brush the monster Deas posted will crunch up?
Sun, Dec 6, 2015 2:04 PM
gauntjoh
Librarian
Thank you received: 5
Reply to old-iron-habit:
Hi Jan,
That D8 8R is also quite unusual in having the right hand drive option, I wonder why that was necessary ?
Sun, Dec 6, 2015 2:36 PM
Reply to gauntjoh:
Hi, Gauntjoh.
We drive on the right side of the car on the left side of the road, just like you. Maybe they didn't want to confuse themselves. Or just maybe they were going anti-clockwise around their fields.
Wunn wundaz.
Sun, Dec 6, 2015 3:50 PM
Andrew
Hi, Gauntjoh.
Wunn wundaz.
G,Day Deas.
This tractor looks to me like an early 1H chassis fitted with a 8R engine. When I was there last week I did not get time to study it properly. The frame serial no is hidden behind the hoe mounting.
Also my understanding is the hoe was used for road building rather than for a farming implement..
Thanks for the photos..
A..K...
Sun, Dec 6, 2015 5:10 PM
Reply to Andrew:
G,Day Deas.
A..K...
Hi, Andrew.
You may be right on both counts. I'm not well enough up on the history of the beast to know. And, as you said, the hoe mounting obscures the rear serial number.
Sun, Dec 6, 2015 5:59 PM
Thank you received: 57
Hi, Andrew.
Deas, can you ask them PLEASE to run the tiller in the paddock so it can be videoed with detailed closeups of the action and post it to youchoob. I've seen too many functional machines go into museums never to run again because some well-intentioned docent decides it's "too old" to run again. I hope this unit isn't one of them.
We don't often get to see these old Cats running mechanical PTO operations (I mean beyond auxiliary functions like CCUs and hydraulic pumps) and this one certainly is unique and I'd love to see it in operation, especially lugging down in some heavy clay.
Sun, Dec 6, 2015 7:25 PM
d4c24a
still a beauty though 👍
https://www.youtube.com/watch?v=ESBY0D5mm0g
Sun, Dec 6, 2015 9:01 PM
janmeermans
Hi, JanM.
[quote="Deas Plant."]Hi, JanM.
Just my 0.02.[/quote]
Holy Smokes! Talk about a commercial cake mixer, that is it! One could make a lot of pizza dough with that "jigger".
Now thinking back, I did not notice one of these Fowlers in Tom Madden's collection. I think he needs one of those too! That way he could really "stir things up" at Santa Margarita. (😊 And Neil and I could watch!
OIH- The "little brother" is also an interesting find. After I posted that the D8 was the largest tiller I had ever seen, I remembered CAT had bought out "somebody" and now make (or once made) major tillers on rubber.
Has Deb figured out how well that thing would prepare the flower garden yet next spring? Why, it would take the frost right out of the ground so she could do an early planting. I'm sure you told her it was a snowblower.
Jan
Sun, Dec 6, 2015 10:44 PM
