96J D5 Cat
96J D5 Cat
Showing 1 to 6 of 6 results
tmoline
Send a private message to tmoline
Anyone know what tooling I need to pull sprockets I have access to Cat press just don't know what adapters i need
Fri, Jun 11, 2021 3:22 AM
gauntjoh
Librarian
Thank you received: 8
Moved Thread to Discussion and duplicate thread deleted.
Fri, Jun 11, 2021 10:30 AM
Thank you received: 66
Sprocket only removal requires:
5F7334 spacer group (1)
5F9040 Arm Group (3)
7F9831 cylinder group (1)
Fri, Jun 11, 2021 12:41 PM
tmoline
Thanks so you have to pull final drive off and then pull sprocket
Fri, Jun 11, 2021 10:19 PM
Reply to tmoline:
If you wish to pull the final drive and sprocket assembly and have a shop do the pressing that is an alternative. Or you can pull the sprocket only after splitting the track and removing the track frame and outer bearing hub and bearing holder. Are you dealing with a spoke type or disc type sprocket? Be wise to get yourself a service manual.
Sat, Jun 12, 2021 1:05 AM
tmoline
been doing this a long time just the service manual says to pull the final off and then press the sprocket off I never done a 5 just 6,7,8,and 9s on those you have a adapter that screws on to the dead axle to attach the press to and I don't see that adapter
Sat, Jun 12, 2021 4:43 AM
Reply to tmoline:
Same operation as the D6. Just uses the 5F7334 spacer. The adapter coupling, pin, threaded adapter and pusher group is for installation.
Sat, Jun 12, 2021 7:35 AM
