!968 12 F blade lift mechanism
Tommyrbk
Send a private message to Tommyrbk
I sure could use a little help! I managed to break the input shaft that goes into the blade lift mechanism, short small splined shaft that goes through a gear (part 7D 4519). Does the big housing have to be removed or will it slide out toward the very front of the grader?? I have drained the oil and removed the four bolt cover but it only comes back so far and then there is a distinct clunk like it us up against a retainer? My book does not explain well enough. Thanks in advance.
Well i decided to pull it off and work on it on my bench. a good cleaning and couple of solid hits with the hammer and off it came. now to go find a input shaft.
Fri, Apr 1, 2016 12:26 AM
Thank you received: 31
Hi Tommy,
well done getting the job done by using your own ingenuity.
Fri, Apr 1, 2016 5:45 AM
