Showing 1 to 10 of 13 results
John in Wy
Send a private message to John in Wy
Howdy, what would a 933 11A weigh? Thanks, John
Mon, Aug 27, 2007 9:50 PM
English Al
Send a private message to English Al
John, the info I have on the weight of the 933 11A is -
933C - 11A 1 - 11A2250 - 1 cub yd bucket -15,500 lbs
933E - 11A2251 Up -16,555 lbs.
Cheers Al
Tue, Aug 28, 2007 12:46 AM
John in Wy
Reply to English Al:
Cheers Al
Thanks Al,
Just what I thought, I need to get a bigger truck and trailer. LOL All tho with the loader assembly off the tractor I could haul it but would have to make 2 trips and it is about 800 miles oneway. Oh well the price of having Yellow Fever. Thanks again. John
Tue, Aug 28, 2007 1:25 AM
B4D2
Reply to John in Wy:
Thanks Al,
John, the guy who hauled my 42A did it with a 24K dual tandem GN and a GMC 3500 Duramax. He also had a JD front end loader bucket and frame pinched in between the GN and the counterweights of my 42A. My machine was quoted as being 17,500, but it also had a set of log forks and about an extra couple of hundred pounds of dried clay on it. If you want to use the VW Rabbit pickup with the landscapers trailer, maybe not. Send me some pics!
Tue, Aug 28, 2007 6:03 AM
John in Wy
Reply to B4D2:
Thanks Bruce, you seen my outfit at Tonto's. A 2003 2500HD with 8100 vortec allison auto and a 20' single wheel 2 axle 14,000# GN. I've grossed 23,300 with it hauling a D17000 Genset. She was MAXED OUT. Did the job tho and no problems, 850 miles. What pics are you looking for? John
Tue, Aug 28, 2007 12:04 PM
B4D2
John, I'd like to see your 11A when you get it. I'd like a shot of the rippers if you can, when you can. Good luck.
Tue, Aug 28, 2007 8:44 PM
John in Wy
Reply to B4D2:
Will do Bruce. Mike said it was an after market, but was done good, when I get it will send detailed pics and if there is a tag or something will let ya know. John
Tue, Aug 28, 2007 11:12 PM
John in Wy
What year would ser number 11A1417 be? Thanks, John
Wed, Aug 29, 2007 6:23 AM
SJ
Send a private message to SJ
The 11A came out in 1955 so I,m only guessing but would say about 1960 or 61. The 11A2596, 933E came out in 1967 according to the Cat SNID book.
Wed, Aug 29, 2007 7:06 AM
John in Wy
Reply to SJ:
Thanks SJ. Would it have the D4400 motor? John
Wed, Aug 29, 2007 10:57 PM
SJ
No the 933 11A has the D311 engine same as the D2 4U & 5U tractors have. The D4400 is the engine in the D4s before the 6U & 7U D4s which use the D315.
Thu, Aug 30, 2007 1:26 AM
