82h662
mattk
Send a private message to mattk
We recently purchased a D5 S/N:82H662. It has steering troubles. The left side slips under a load and the right is hard to turn. I am looking for year model, hp, weight, and a reputable place to purcase a service manual. I am new here. I am impressed with the knowledge here. Thank You for any help.
Fri, May 30, 2008 10:12 AM
SJ
Send a private message to SJ
The Cat SNID book says they started production in 1967 so as low a SN as it has I,m guessing it came out that year yet or 1968. A book I have says they had 93 HP but I don,t have the weight of it as it wasn,t listed in this Classis Caterpillar book I have by Keith Haddock & Eric Orlemann.
Fri, May 30, 2008 6:29 PM
Reply to SJ:
The info I have shows only one year of production (1967).
Basic weight is 18,600 lbs.
D333 engine at 93hp.
The manuals for such a limited production might be a little hard to find or combined in one of the many similar model service books.
You could try here under "track tractors" (doesn't seem to be working this am😕 )
http://www.cat.com/cda/layout?m=90800&x=7
Fri, May 30, 2008 10:14 PM
Was able to get in to the Cat Literature site.
They show a parts book Form # UEO70061 @ 220 pgs.
Operation & Maintenance manual Form # FEO45079-03 @ 96 pgs.
But I could not find a Service Manual specifically for the 82h.....I suspect the service manual for the 93J is probably about as close as you will get.
Sat, May 31, 2008 8:07 AM
