80% under carriage
80% under carriage
eric in gilroy
Send a private message to eric in gilroy
what exactly does this mean?? is it better to have 80% or 60%? I saw a chart how to measure track wear so i am thinking if the seller says the tractor has 80% under carriage then that means, you only have 20% of life left in tracks sprockets and etc.
Is this correct?
Fri, Mar 1, 2013 6:12 AM
Orchard22
Send a private message to Orchard22
He most likely means percentage of life left in the undercarriage.
1935 Caterpillar
Twenty-Two Citrus(or low top seat orchard)
serial number:2F2204
Fri, Mar 1, 2013 6:33 AM
d9gdon
[quote="eric in gilroy"]what exactly does this mean?? is it better to have 80% or 60%? I saw a chart how to measure track wear so i am thinking if the seller says the tractor has 80% under carriage then that means, you only have 20% of life left in tracks sprockets and etc.
Is this correct?[/quote]
It means that you have 80% of the life of the undercarriage left until it's worn out. It is very often approximated or guessed at and you can bet that it'll never be more than what's claimed. You can measure it yourself with calipers and the "as new" specifications which you can obtain from the manufacturer with the SN and/or arrangement number.
Fri, Mar 1, 2013 7:39 AM
D349
Send a private message to D349
Reply to d9gdon:
G'day. I have a 1989 copy of the Caterpillar Custom Track Service Handbook which is the cat bible on undercarriage wear of that time. Its charts for all of the tracked machines listed start at 0%worn for new dimension parts through 100% and beyond as worn out. So by Cat 80% worn would be only 20% wear left but lots of people when describing a machine will say a machine has 80% undercarriage mean it has 80% wear left so be careful and clarify if possible.
Kevin
Fri, Mar 1, 2013 9:57 AM
eric in gilroy
Reply to D349:
Kevin
[quote="D349"]G'day. I have a 1989 copy of the Caterpillar Custom Track Service Handbook which is the cat bible on undercarriage wear of that time. Its charts for all of the tracked machines listed start at 0%worn for new dimension parts through 100% and beyond as worn out. So by Cat 80% worn would be only 20% wear left but lots of people when describing a machine will say a machine has 80% undercarriage mean it has 80% wear left so be careful and clarify if possible.
Kevin[/quote]
ok i feel better now ,cause every time someone tells me a number i ask them what exactly they mean and have heard both versions from people that have been around track layers for years.
Sat, Mar 2, 2013 10:33 AM
Jon Auty
Send a private message to Jon Auty
Reply to eric in gilroy:
Kevin[/quote]
i spent 9 months on track inspection and machine inspection duties for the uk cat dealer Finnings, i think i still have a copy of the CTS handbook somewhere if anyone requires it. i did manage to drop on a home made D2 track gauge which i used for inspecting my D2 3J, i can reproduce them if anyone is interested? gives you a rough idea on how much wear there is in your undercarriage
[attachment=16448]img006.jpg[/attachment]
Mon, Mar 4, 2013 2:46 AM
jdkoller
Send a private message to jdkoller
Reply to Jon Auty:
I wouldn't mind having one.
Mon, Mar 4, 2013 3:00 AM
Jon Auty
Reply to jdkoller:
i'll see about getting them profiled out in mild or stainless steel and see what the cost will be if i get a bulk order in
Mon, Mar 4, 2013 3:03 AM
Soapy
Send a private message to Soapy
Reply to Jon Auty:
I'll take one!
Mon, Mar 4, 2013 4:23 AM
