recently started working at this shop. Machine is used constantly only recently has this issue become more pronounced. any suggestions on where to start looking? it has the power shift trans and fluid level is good. high range works with light load unit has no low range will not move at all.
I show a 79V 140 to be a Timber Loading Crane (not Cat). Is that what you have?
A V140 is a Caterpillar lift truck sold in the 70's.
Chevelle you need Caterpillar form REGO 1404-01 systems operation testing and adjusting specifications available from Cat .
That powershift transmission doesn't have a clutch it has a inching valve.
Bob
