71D Circle Stuck
71D Circle Stuck
D4Doug
Send a private message to D4Doug
After a few hours of snow plowing fun, my CAT 71D Grader blade circle is stuck. I can move it only in the clockwise direction but not the other. Anyone have any ideas? I tried putting one end of the blade in the ground and easing ahead while ingaging the control lever. Outside of shaking my filings it did no good to unstick the blade.
Sun, Mar 29, 2009 10:53 AM
OzDozer
I'd suggest the problem is either in the small reversing gearbox that is mounted in the A-frame, that reverses the direction of the control shaft .. or in the circle gearbox itself. I'd say maybe a bearing has broken up, or has misaligned the drive components, resulting in the drive actuating in the one direction, but twisting out of gear alignment when reversed, thereby jamming the gears.
Sun, Mar 29, 2009 4:39 PM
ol Grump
Reply to OzDozer:
Also you might look at the spacer blocks on the circle and make sure one of those hasn't come loose and jams the circle one way.
Sun, Mar 29, 2009 7:41 PM
D4Doug
Reply to ol Grump:
Thanks Oz and Ol'Grump, will try to see what I can discover as soon as I can get a little free time.
Mon, Mar 30, 2009 3:29 AM
D4Doug
Reply to D4Doug:
Ol' Grump wins the prize. One of the adjusting nuts had fallen off from the circle guide shoe. The guide shoe then worked like a cam. It allowed enough slack for the circle drive mechanism to disengage from the circle teeth. Had to pull it back it to place with a few discrete tugs from the 930 with a chain on the moldboard. Then I replaced the missing bolt and adjusted the shoes. Now the circle turns true and I am ready for the next snow storm due tonight.
Thanks for the help guys. This is the best place to come for good advice.
Mon, Mar 30, 2009 5:45 AM
ol Grump
Reply to D4Doug:
D4Doug,
I'm glad it was that easy of a fix. It sounds like you're good to go again.
Mon, Mar 30, 2009 8:12 PM
| Kingaroy, Queensland
