650 BE-GE pump question
Showing 1 to 10 of 14 results
FLDrew91
Send a private message to FLDrew91
Good evening guys,
Im about to start stripping and resealing my Be-Ge pump but wanted to know if it would be enough for a dozer blade. From my search I found the specs for it, 56 gpm @ 1000 rpm 500 psi. I’ll admit I’m a little ignorant about hydraulics so I’m doing my research before I half a** engineer a system. It’s rear mounted and almost all of the “dozers” I’ve seen have been front mounted. I don’t really want to buy another pump and since this one came with the tractor I though it would be nice to utilize it. Also, any input on what else it would be useful for is much appreciated.
Thanks!
Current project: 1936 RD4
Thu, Aug 16, 2018 7:56 AM
Thank you received: 66
The #650 pump is rated for 850 psi operation max.
The problem with these low pressure pumps is that they require large bore cylinders.
No reason you can't run a blade with this pump if cylinders are matched appropriately. You do realize that it only pumps when in gear and engine main clutch engaged depending on application.
These pumps have a rather different and obsolete sealing system that may need to be overcome and worn shafts and bearings severely affect performance with severe leakers blowing cover gaskets and may even warp the covers.
Thu, Aug 16, 2018 9:42 AM
Casey Root
If you do use the rear mounted BeGe, be sure and build some sort of protection around the valves, hoses and tank. You will back into something and bust things with out a guard. The voice of experience. LOL!!! We had good success with a BeGe on a farm style blade attached to an AC HD9. Even put a tilt cylinder on it.
Casey
Thu, Aug 16, 2018 11:01 AM
Paso Bob
Reply to Casey Root:
Casey
I operated a 7U D-4 and a 3T D-7 for years with BeGe pumps and never had an issue. The D-7 is still a working dozer and has lots of dozing hours on it. Having the Cat pump powered by the front of the crankshaft with live hydraulics does tend to spoil a person. Like OM said, the rear mount only pumps with the master clutch engaged.
Thu, Aug 16, 2018 11:44 AM
FLDrew91
Reply to Paso Bob:
Thanks fellas. OM, I am aware that it’ll only pump with the clutch engaged, that one of the reasons why I wanted to ask my superiors. Would the cylinders hold their position during gear changes? My thought is no but since I haven’t operated the system I’m assuming.
Fri, Aug 17, 2018 1:06 AM
Casey Root
Reply to FLDrew91:
It will hold during gear changes. The biggest issue we found dozing with ours was, no float position and BeGe valves are notorious to wear and leak by. We seemed to send them regularly to Rutter Army to get them tightened up. OOOORRR just let them sag to the implements stops.
Fri, Aug 17, 2018 1:25 AM
FLDrew91
Thanks. Would a 4” bore be large enough to work with the pump? I’ve looked around and found several I think would work.
Fri, Aug 17, 2018 2:11 AM
Reply to FLDrew91:
What tractor/blade are you working with? 4" bore cylinders (2) happens to be what the BeGe blade on the D6 used back in the day. I'd say that would be minimum size.
Fri, Aug 17, 2018 2:33 AM
FLDrew91
Old Magnet, my tractor is a RD4 and I have an unknown blade setup that was given to me, it includes the frame and trunions. The frame is a few inches wider than my guage and I’ll have to fabricate new trunions mounts.
Fri, Aug 17, 2018 3:53 AM
d2gary
Reply to FLDrew91:
My tractor came to me with a jumper and a valve between both sides of the valve. It equalizes the pressure on both circuits and let's the blade float by opening the valve. It does work ok but it doesn't react as fast as true float equipped valve.[attachment=50323]20180816_172659.jpg[/attachment]
Fri, Aug 17, 2018 7:51 AM
Reply to FLDrew91:
That's to much pump for the D4 @ 57 gpm and 1000 rpm it requires 34 hp. The 650 is more appropriate on the D6, 7 & 8.
Running at 500 psi vs 850 will save some hp but that's not good with 4" cylinders.
Fri, Aug 17, 2018 9:51 AM
