56 d6 9u hyd blade problem
Showing 1 to 10 of 13 results
7mileranch
Send a private message to 7mileranch
Was clearing and stacking bush today on a pile. Heard a large bang or snap, blade quit working and hydraulic fluid is all inside the front. Any ideas where to start. Going to try and find a manual. Can someone help where to find the hydraulic serial number thanks.
Wed, Mar 11, 2015 3:53 AM
chriscokid
can you have someone look while you try to operate the blade to pin point the general location of the problem?
Wed, Mar 11, 2015 4:14 AM
7mileranch
Reply to chriscokid:
had to shut it off couldn't get the blade off. stuck pin, didn't want to wreck the pump. Although I suspect its wrecked, With the snap I heard and oil eveywhere must be a gear. Going to take the guards off and have a look.
Wed, Mar 11, 2015 4:22 AM
Thank you received: 66
Reply to 7mileranch:
There are no gears in there.
May have lost the u-joint coupling which would allow the pump flange to back off letting the oil out.
S/n is on the top of the tank where the control lever enters the unit.
Wed, Mar 11, 2015 7:25 AM
rjh-md
Send a private message to rjh-md
Check the u joint from front crankshaft pulley to hyd control .Also could have a broken cylinder rod at piston in one of the hydraulic cylinders .Pumps don't usually fail all the sudden with a bang .Thats a vane type pump in the tank .
My money is on a broken rod
Wed, Mar 11, 2015 7:33 AM
rjh-md
Reply to rjh-md:
I forgot there are hoses there too !Maybe just a busted hose thats hard to get at on that set up
Wed, Mar 11, 2015 7:36 AM
Reply to rjh-md:
You blew a hose. remove the hood and top rad. shroud n have look. not with the engine running though.
Wed, Mar 11, 2015 8:10 AM
7mileranch
Took belly pan off looks like it was just one of the hoses rubbing on the frame. Must have been one of the loose c-frame pins made the noise hopefully. Took the hose off. Any ideas where to get theses fixed.
Wed, Mar 11, 2015 8:24 AM
Not sure of the ends on your hose but most larger auto parts stores (NAPA) repairs hydraulic hoses and almost all Farm Equipment Dealerships do hoses also.
Wed, Mar 11, 2015 6:20 PM
Thank you received: 62
Reply to drujinin:
Rather hard to change to a different type,so most likely still the o ring flange,the original had bolt down clamps on the hose.If it was changed to crimped clamps you may still be in luck as Cat had some that where reusable of those,but I think those where being fazed out when I discovered they where reusable(15 years ago). Hopefully a hydraulic shop would know about the Cat reusable clamps even if they don't have the tooling to reuse.As always picture are your friend for more complete information,but I am not able to do that so understand if you don't ether.
Wed, Mar 11, 2015 8:26 PM
7mileranch
Reply to Ray54:
Yes they are the o-ring flange with bolt down clamp. Hasn't been changed in the forty years since dad's owned it. The whole dozer is a fairly simple system actually. I'm not the most mechanically inclined, but I can work on most of it other than the deep stuff.
Wed, Mar 11, 2015 9:23 PM
