#44 fluid
#44 fluid
Showing 1 to 6 of 6 results
Elton
Send a private message to Elton
Good afternoon!  I have my #44 hydraulic unit off my tractor for a seal replacement.  What hydraulic fluid is recommended?  I have been using AW32 but it seems extremely slow to raise the blade.  The tractor is a D4 7U36219 and the hydraulic unit is 9W7594.  Thanks again for all the great help I have been given.  Elton
Tue, Oct 31, 2023 1:54 AM
10W Hyd oil [Phillips Power Drive]
Tue, Oct 31, 2023 3:02 AM
seiscat
AW32 is correct. My family have all used heavier SAE rated AW oils with success in high hour(worn out!) machines. It all depends on your climate.
Craig
Tue, Oct 31, 2023 3:20 AM
Thank you received: 54
anti wear 32 is too thin you want iso68 or better yet caltex textrans tdh which is a universal tractor driveline oil its for the differentials, transmission and hydraulics of most brands of tractors and has cat to-4 approval and can be used in the trans and hydraulics of virtually all the older non power shift machines.
Tue, Oct 31, 2023 3:24 AM
Elton
Reply to trainzkid88:
Thanks guys for your assistance! Given the age of the machine and how it has behaved, I think the thicker oil might be the ticket. Elton
Tue, Oct 31, 2023 3:35 AM
Elton
[quote]I have on order a Speedi-Sleeve and seals and the necessary O rings. I am debating on removing the pump and checking it out. Does one remove the several bolts that are behind the seal retainer and pull it out? Or does it have something on the inside that must be removed first? Thanks again for the help! Elton
 [/quote]
I seem to recall having to take off the main (front) cover, disconnecting some items (probably tubes) before removing the pumps. Wouldn't be a bad idea even if you don' tneed to in order to clean it out. Gasket for the cover is available from Cat.
Wed, Nov 1, 2023 11:39 PM
willwingo
Thank you received: 8
Caterpillar Form 31677-1, Operations and Maintenance Instructions for the No. 44 Hydraulic Control specifies S.A.E. No. 10W crankcase oil for temperatures above 0* f.
Thu, Nov 2, 2023 1:57 AM
