343 repower
343 repower
earthworm
Send a private message to earthworm
am trying to repower a 834 wheel dozer that has a343 and would like to get rid of it over heats to easey?
Thu, Dec 8, 2011 5:47 AM
bob
Send a private message to bob
Ross, the easy overheat is a problem on it's own. If it's not an engine problem/timing or a blown head gasket it may follow you with the replacement engine. The next problem is fabricating engine mounts to hold the best choice(343's grandson 3406) in alignment with the trans. Then mounting all the pumps and fabricating the suction lines to fit them. It all could be done but it will cost plenty. Then the fuel system of the new engine needs to be set to deliver an identical torque curve as the 343 has. Not the job for you to take on by yourself, if everything is not perfect you will have expensive breakdowns one after another. My advise to you is Clean or recore your rad, rebuild the existing 343 properly and you will be happy. If that sounds too expensive PART HER OUT.
Later Bob
Thu, Dec 8, 2011 7:05 AM
earthworm
Reply to bob:
Later Bob
thanks bob do 343 in scrapers tend to over heat? replaced the rad last year just want to get the scoop before rebuild
Thu, Dec 8, 2011 9:22 AM
bob
Reply to earthworm:
Overheating was never a cronik problem with that engine Ross.
It can come from many sources. Rad pressurizing(blowing coolant out the overflow)
Throttle linkage out of adjustment and not getting high idle.
Increased rack setting for more power. Timing incorrect due to wear.
Dirty air cleaners, bad turbo, not getting enough air.
Faulty or no temp regulators. They control the bypass line and if there are no regulators installed
too much coolant will bypass the rad.
If you still have the machine runable get an inferred thermometer and check the top and bottom rad temps.
Should have a 10 to 15 deg F temp drop from top to bottom tank. Too little diff, rad clogged externally,
too much diff, rad clogged internally.
Later Bob
Fri, Dec 9, 2011 7:44 AM
| Kingaroy, Queensland
