3204/d4h Lgp
3204/d4h Lgp
Gordon.
Send a private message to Gordon.
Just to keep us on our toes we have decided to tackle the 3204 engine "water in the oil" problem with this. In the past, we have encountered a porous block with this model of engine, however, head gasket being the first thought on this unit. Before we commence with removing the head would i be right in saying that there is another possibilty, that being water can travel into the oil through a water connection in the front cover, this being an option would you suggest we remove the front cover and check as i see no way of testing for this particular faliure?
This will almost certainly require us to replace the sump gasket, is this possible on this engine as fitted into a D4H tractor??
Regards Gordon
Mon, Oct 5, 2009 2:11 AM
d4e
Send a private message to d4e
Gordon, It seems to me the only time I have ever had waterin the oil on one of my D4E SAs is there was a water pump problem. I can go back through my maintenance records to verify for sure. I can check on Monday.
Mon, Oct 5, 2009 3:17 AM
Gordon.
Reply to d4e:
D4E, yr D4 has a gear driven water pump so if the gland seal fails the water will enter the oil. The 3204 engine has a belt driven water pump and therefore no direct conection with the oil. The 3304 engine you have is bullit proof ! one of the best.
Regards Gordon.
Mon, Oct 5, 2009 3:36 AM
