#29 CCU Wrench
#29 CCU Wrench
1972RedNeck
Send a private message to 1972RedNeck
Anyone have a picture of the 3/4" wrench needed to adjust a #29 CCU? Angle wrench won't quite do it. Angle wrench, pump pliers, and vice grips will eventually get it done.
Did Cat make a wrench? Part number?
Thu, Jan 30, 2025 9:16 AM
Thank you received: 140
Hi, 1972Redneck
I think I still have a 19mm/3/4" ring wrench from the toolkit ovva Suzuki LJ50 4WD which I bent specifically for getting at the top neutral adjusting nut onna Cat #25 CCU back in about 1975. I doubt that a Suzuki mechanic would have recognized it when I was done. But it worked - and still did some other jobs too. Sorry, don't have a photo of it.
Thu, Jan 30, 2025 6:29 PM
D8Dude
Thank you received: 28
Hi, 1972Redneck
I have found that a crow foot spanner on a ⅜ drive ratchet has been most effective for me, hope this helps.
Fri, Jan 31, 2025 1:42 AM
