235 excavator swing lube
23 KV
Send a private message to 23 KV
Happy Mothers Day !
Servicing a ''new to us'' Cat 235 excavator.
We got most of it complete and then found the SWING GEAR and pan area , clean, dry , no grease.
Whats up here ? My book says 10 gallons of grease.
The teeth look great . So no damage done .
Dave
Mon, May 9, 2016 1:07 AM
Hi,
welcome to the BB.
The swing pan and gear are indeed loaded from the factory with that volume of grease--and the gear teeth are supposed to be re-lubed with grease at regular Service Intervals--seems most people use a suitable piece of board/paddle or stick to re-distribute clean grease from the pan to the big gear teeth by swinging the House around a few degrees at a time.
After a while new grease needs to be added.
Seems like on yours some work was done in that area and not refilled--we used to do the big gear and pan before we put the top/house/upper structure back on--or heaven forbid it was missed at the factory.
We found most clients were not aware of the swing gear pan servicing cover -- in under the boom mount area--if I recall correctly.
Mon, May 9, 2016 6:31 AM
23 KV
Reply to edb:
Hi,
welcome to the BB.
ebd,
Thanks much for the reply. Looks like I have lots of grease to pack huh !
Dave
Tue, May 10, 2016 8:05 AM
