231D excavator
231D excavator
tacacat
Send a private message to tacacat
Hello Everyone-
I'm looking at purchasing a Cat 231D late 80's , (I'll be digging a pond) anyone own one , Pro's/con's of machine , 3208 T engine
I have hard pan clay soil W/ some shale ( upstate NY ) Does the 3208 T( 200 hp claimed) provide ample power to run an 80K Lb machine ? the undercarriage is weak, I am trying to work on owner for 12K purchase price.
any insight will be appreciated
Thanks Tim
Sun, Sep 28, 2014 2:05 AM
MARCOTEN
i Always heard that the machine cat made between the 225 and the 235 : the 231 was not that good, bad of both worlds , so consider an other option if you have that.... goodluck!!!
Sun, Sep 28, 2014 5:03 AM
rturn3060
Send a private message to rturn3060
Reply to MARCOTEN:
The 231 is a 225 with the smoke screw turned up on a 235 under carriage which if badly worn would indicate a lot of hours on it. If you want production from an old piece of constructon equipment be prepared for some expensive repairs
Tue, Sep 30, 2014 10:10 AM
tacacat
Reply to rturn3060:
Both are in the 18K $ range
Fri, Oct 10, 2014 1:44 AM
MARCOTEN
Reply to tacacat:
the deere wath weight is it? , ( here it has the name Hitachi, or fiat Hitachi) it were good machines, for all machines is the rule the more hours on the clock the worse they are or maintanance is more required, for old machines is also the problem the rubbers seals are now getting more hard/ solid so more chance for leakage.
Fri, Oct 10, 2014 2:05 AM
