215 excavator stick dimensions
Reisingerweld
Send a private message to Reisingerweld
Does anyone have a the dimensions of the bucket end of a cat 215 stick, the proper stick width and pin diameter, and if the dog bone dimensions are any different? Prefix is 57Y. Thank you
Fri, Jun 23, 2023 5:31 AM
Deebo
Librarian
Thank you received: 105
Think there were 3 stick lengths, 5‘11“, 9‘2“ and 7‘3“. I don’t know if this meant the dimensions you asked for were different depending on the stick length?
Fri, Jun 23, 2023 2:33 PM
GMBM
Send a private message to GMBM
Reply to Deebo:
The nose of the stick is 11 inch with 2 3/4 pin
The H link should also be 11 inch with 2 3/4 pin an old chart I have shows some at 10 3/4 wide but I dont ever recall seeing one
215D did switch to a 3 inch pin on the stick
Greg
Sat, Jun 24, 2023 5:54 PM
Reisingerweld
Reply to GMBM:
Greg
Ok thanks guys I'll have to pull the machine apart I guess to confirm before I make a wrong move. Thanks
Mon, Jun 26, 2023 10:17 PM
